1500 hd ?
Hi all need your help. Trying to help a guy with choosing the correct spindles for his truck. I have seen there are two different spindles for the 2wd GMT 400 trucks.
The only thing I know is that he have a 91 1500 2WD 5 lug truck, as of now I donīt know which cab and bed. He is claiming he have an HD truck but I doubt there ever was such a thing. I have seen 1500 HD but only 99 and up and those were 8 lug. Was there ever a 1500 HD truck during the 88-98 period? Maybe he is just refering to the two different type of spindles as being light duty vs heavy duty. Thanks
Mats.. ---------------------------------------------------- 1971 Cheyenne Super Custom Camper 475CBB/TH400/AC 1992 Silverado Sport Truck 1988 Silverado 2500 Ext Longbed 4x4 2001 GMC Sierra SLT 4x4 1990 Chevrolet K3500 1965 Pontiac Grand Prix 1980 Z 28 350/4-speed/AC/T-top 1980 Camaro Coupe V6/3-speed 1979 Buick Century Wagon |
Re: 1500 hd ?
Most 1/2 ton gvws were 6,000-6,200. There was a f44 rpo code that was available on 1/2 ton trucks and it had 7,200 gvw. It wasn't marketed as "hd".
The light duty 3/4 ton had the same 7,200 gvw where the heavy duty had 8600. The first year for the 1500hd was 2001, and it had a gvw of 8600. |
Re: 1500 hd ?
Thank you 95 for reply.
You answer confirms what I was thinking about a 88-98 1500 HD existence. My friends problem was he had bought new drop spindles for his truck but they turned out to not fit. I have learned that there are two different spindles for 88-98 2wd 1500 trucks. 4" shaft spindle for 1" disc brakes and 4.5" shaft spindle for 1.25 disc brakes. The 1" discs were used on 88-91 reg cab trucks (except 454SS) and all other 88-98 2wd 1500īs used the 1.25 discs. I have also seen that the two different spindles sometimes refers to light duty vs heavy duty, that is probably the reason he says his truck is a HD truck. So probably he bought the 4" spindles but what he really need is the 4.5" ones.
driving is in my blood
Re: 1500 hd ?
8600gvw 1/2ton truck. Insanity.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
Re: 1500 hd ?
Re: 1500 hd ?
'88-'91 1500 2WD regular cabs used the "light duty" spindles. Light duty means the axle pin is a smaller diameter (1" I believe, it's been a long time), so it uses different bearings and rotors.
All other '88-'91 1500 2WD trucks and ALL '92-'98 1500 2WDs used the "heavy duty" spindles with a larger axle pin (1.25"). |
#7 | |
Re: 1500 hd ?
Now that I looked in to this I know which spindles to look for for my 92 Sport truck. Planning on doing a 2/4 drop on it some time. Thank you all for your help.
Re: 1500 hd ?
I'm glad I read this thread. Always learning. I knew there was a light duty 2500 in these years, but all those were 6-lug. So, no designated 1500HD, but in '92 went to heavier parts on all the C1500s
| Bookmarks |
