![]() Join Date: Jun 2007
WTB: 1963 specific factory power brakes
In 1963, Chevrolet and GMC began moving away from the Chevrolet Hydrovac and GMC Midland inner-fender mounted power brakes used from 1955 thru 1962, to the first firewall mounted system which had vertical booster brackets attached to a special flat steel spacer (see photos). In late 1963, GM went to a newer power brake design that allowed better air cleaner and engine area clearance which employed the use of the common "wedge" shaped aluminum spacer and horizontal mounting brackets you generally see on all 64-66 trucks. So only the earliest of 1963 trucks would have come with the original design w/ flat non-wedge shaped firewall spacer you see below. Most often found on 1 ton trucks, but available on 1/2 and 3/4 ton 1963 models.
If any of you have one or know where one is, or have accidentally bought a setup off a 1963 that you are intending to install on your 64-66 project I am perfectly willing to trade you the correct one for your truck in order to get one of these early 63 setups. Let me know what you have?
My Projects and Toys - All 100% Stock 1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction 1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar 1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock 1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd 1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet 1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight 1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB 1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet 1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet 1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet. |
Re: WTB: 1963 specific factory power brakes
Are you looking for just the steel plate?
If that's all, you could easily make one or have one made. -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
yes, but you'd need an original to use as a template - there is a flange to the center hole to retain the rubber, and the precise alignment of the holes is important etc - I wouldn't want to guess at it
I bet Captain Fab could make one in less than 10 seconds if he had an original to go by
