Old 10-14-2003, 06:04 PM   #1
72MARIO
72MARIO's Avatar
Thumbs up My Flip Down Tail Light Gas Filler.
Here are some pic's of My flip down tail light gas filler.
I had to cut the stake pocket out of the box and some of the rear box crossmembers. I also had to do extensive mod's to the tail light housing. I also had to remove 1/16 of from under the tail light opening in the box side. I used a cabinet hinge fromHome Depot. For the filler tube I cut the old neck off of a tank.( I filled the tank with water) Then I heated the neck up and removed the filler ring that the gas cap clips into.(It was soldered on) I welded it to the exhaust pipe that I had bent up. I still need to get the L.E.D's from Early Classics. Frigging Expensive though. Oh I had to flip the taillight housing too. I was planning on using a Blazer tank but the plans may change.
Here are some pic's
I will never do this mod again ! I am not kidding.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 10-14-2003, 06:05 PM   #2
72MARIO
72MARIO's Avatar
Filler
2005 TAHOE DD
Old 10-14-2003, 06:07 PM   #3
pissonNOS
senior member
pissonNOS's Avatar
would you recommend it to someone to try?
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 10-14-2003, 06:07 PM   #4
72MARIO
72MARIO's Avatar
Hinge
2005 TAHOE DD
Old 10-14-2003, 06:10 PM   #5
72MARIO
72MARIO's Avatar
Opps'
2005 TAHOE DD
Old 10-14-2003, 06:12 PM   #6
72MARIO
72MARIO's Avatar
I hate this!
2005 TAHOE DD
Old 10-14-2003, 06:14 PM   #7
72MARIO
72MARIO's Avatar
I would never do it again. I would rather spend the time somewhere else. And run the filler thru the bed floor.
2005 TAHOE DD
Old 10-14-2003, 06:22 PM   #8
70c10
67-72 Addict!
70c10's Avatar
Alot of hard work but still a pretty trick mod!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 10-14-2003, 06:23 PM   #9
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
Just wait until you start crusing and showing your truck. The compliments you will get at the gas station and other places will make up for the frustration. :p
BTW: That is freaking slick man!
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 10-14-2003, 07:07 PM   #10
crazy longhorn
Fabricate till you "puke"
some of those mods that you think will be "minor", do really take some time. anything that "moves" will be more work......it sure looks good tho crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-29-2004, 09:36 PM   #11
68gmcdually
68gmcdually's Avatar
72MARIO: I guess that you don't want to drive up to my place in Fenelon and try that mod on my truck then.
James Bellwood
1968 930 Extend-A-Cab Dually 5.7l, 5 speed,
68gmcdually is offline   Reply With Quote
Old 12-29-2004, 09:52 PM   #12
ebfabman
Mario, have you tried to open it with the bumper installed yet? With the bumper on, will it open enough to get the fuel pump nozzle in the filler?
ebfabman is offline   Reply With Quote
Old 12-29-2004, 10:21 PM   #13
longnlow72
longnlow72's Avatar
ebfabman, im guessing by his truck he will have a roll pan not a bumper, that is a sweet mod
72 Chevy lwb, cowl hood, shaved antenna, shaved bedrails, blazer tank, sidemarker fill, 1pc windows, flowmaster 40's, alpine deck, infinity 6x9's, infinity 4"ers, 2 jl audio 10w0's, grant wheel, keyless entry and alarm, more waiting to be done...
longnlow72 is offline   Reply With Quote
Old 12-29-2004, 11:19 PM   #14
Blue Beard
Blue Beard's Avatar
All good things come to those who wait.....and it looks good.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 12-30-2004, 11:43 AM   #15
72MARIO
72MARIO's Avatar
Wow this is old.
I have actually trashed this idea. The light cleared the bumper but I could not get a hinge that had no side to side play. So whenever I closed it the tail light housing would hit the inside of the light opening and if the truck was painted in time it would chip/wear all of the paint off. There was like 1/16" of side to side play at the top of the light it would hit either side. I feel really bad that I gave up on this Idea it was such a cool mod but I just did not have the tallent to custom fab my own hinge at the time. I have installed a 20 gallon fuel cell form summit with a fule sending unit. I am using a stainless gas filler for a boat and sticking it in the wood floor. The Blazer tank I was planning on using hung way too low and I would have had to hack out all of the crossmember to clear the tank.
2005 TAHOE DD
Old 01-26-2005, 08:40 PM   #16
71Longbed
Not Mine But A beauty
71Longbed's Avatar
which summit fuel sell did you get and how low does it sit?
68 Chevy Shortbed 454/400
2000 Chevrolet Camaro SS 6spd
2011 Silverado 5.3 6spd auto
71Longbed is offline   Reply With Quote
Old 01-26-2005, 09:18 PM   #17
72MARIO
72MARIO's Avatar
The fule cell I am using is aluminum 24x20x10 " it has a 0-90 ohm sending unit too. The fuel cell is 10 inches deep so it should hang down about 5 inches.
2005 TAHOE DD
Old 01-26-2005, 09:40 PM   #18
Low69CST
Mario i'm considering the same mod, what gave you so much headache with it?
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 01-26-2005, 09:44 PM   #19
longnlow72
longnlow72's Avatar
low69cst,
Originally Posted by 72MARIO
Wow this is old.
i think this is what u were asking
Old 01-27-2005, 12:35 AM   #20
Low69CST
sorry, i'm slightly intoxicated tonight.
Old 01-27-2005, 02:07 AM   #21
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Mario, How are you doing your wood bed with that big drop? I am sure you must have notched the rear...right? I love the wood but am not sure how it will look stepped. Maybe just do the flat part in wood and cover the notch in sheet metal.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 01-27-2005, 08:03 AM   #22
Anyone try a car tank/tag-fill?I had this in a`69 PowerWagon,a 68 Coronet tank.Starting to think of looking into it.
Old 01-27-2005, 07:07 PM   #23
72MARIO
72MARIO's Avatar
Here is a pic of how You could notch the wood floor If you step notched the frame. It's not necessary with a C notch. I can have my axel hit the frame and the pumpkin will not hit the wood floor. I have not notched the frame though. I think if I notch the frame I coulds only get another 2" drop before the pupmkin hit's the wood floor. So a not in my case it would not be worth notching the frame.
2005 TAHOE DD
