Old 01-20-2017, 06:39 PM   #1
Foureye71
Foureye71's Avatar
Shift happens
So yesterday morning while I was on my way to school. I had parked my truck and was putting it into park and heard a loud pop/bang and I broke the ball off the end of the shifter. Usually its a little tough to take it in and out of park when its a little cold out. So I've got 2 questions now 1. are repop shifters any good and 2. whats the best way to get the broken ball out of the column?
'71 K1500 Short-Wide
Foureye71 is offline   Reply With Quote
Old 01-20-2017, 06:49 PM   #2
70cst
70cst's Avatar
Re: Shift happens
Here s a bump for you
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 01-20-2017, 08:20 PM   #3
70STOVEBOLT
70STOVEBOLT's Avatar
Re: Shift happens
If you have a telescoping magnet you may be able get it out with that. Why is the shifting mechanism so stiff? Shouldn't be hard to shift an automatic unless something is in a bind.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 01-20-2017, 08:48 PM   #4
wbc409
Re: Shift happens
I would put money on a worn parking pall. This would allow the truck to move slightly putting pressure on the mechanism making it hard to shift out of park. Most tranny shops don't replace those parts unless they are broken or noticebly worn.
I would try a small magnet to fish what is left of your shifter out of the column.
wbc409 is offline   Reply With Quote
Old 01-20-2017, 09:20 PM   #5
randy500
Re: Shift happens
I just removed a broken ball in my column, came right out with one of those telescoping magnets. When you put a new lever in spray wd-40 in the column above the bowl and in the shifter hole to lube it up. Do the same on the engine side while prying the shift lever away from the detent plate. The shift column slides on those 2 areas and it needs lube.
randy500 is offline   Reply With Quote
Old 01-20-2017, 11:37 PM   #6
custom10nut
custom10nut's Avatar
Re: Shift happens
The inside of your column needs to be cleaned out. 40+ years of dust have built up inside and gummed it up to the point it won't move any more.
This could be a motivator to get a new tilt unit.
custom10nut is offline   Reply With Quote
Old 01-20-2017, 11:43 PM   #7
custom10nut
Re: Shift happens
Old 01-21-2017, 02:36 AM   #8
Foureye71
Foureye71's Avatar
Re: Shift happens
I had figured my column was gummed up with stuff because it was super easy to put the truck in and out of park in the summer. I'll try to fish out the remains of the shifter with a magnet. I don't think a new tilt column will be coming, they're a little too much money for me at the moment.
Old 01-31-2017, 03:16 AM   #9
Foureye71
Foureye71's Avatar
Re: Shift happens
*UPDATE*
I had a little extra time to kill today after I got home from school and decided to fish the remains of the shift lever and the majority of the plastic bushing.
