Old 01-20-2017, 07:48 PM   #1
ratrod67
ratrod67's Avatar
Bleeding brakes on a 97 Tahoe.
Trying to get pedal pressure on a 97 Tahoe. Had a rear wheel cylinder blow out and lost fluid. Installed new wheel cylinders on both back brakes and new front Disc pads. Bled brakes like I have done for last 25 years and couldn't get any pedal pressure. Installed new master and re-bled 5 different times and still no pressure. Goes to the floor. Any ideas? Only thing I am not familiar with is the Tahoe has a hydro boost brake system. Is there a different method I need to use to get pedal pressure? The brake pressure was fine before the wheel cylinder blew out. It is not leaking fluid anywhere so I doubt air is getting back in the lines.
ratrod67 is offline   Reply With Quote
