Tire width for stepside w/ 71+ rear axle
Hey everyone, I'm trying to figure out what kind if tire width can be fit under a stepside with a slightly wider 71+ rear end, I'm not entirely sure of the backspacing of my rims but they are stock 16" stealies from a 78. Wondering if a 9" or 10" wide tire will fit. Any help appreciated
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
Re: Tire width for stepside w/ 71+ rear axle
Anyone?
![]() Join Date: Aug 2014
Doesnt seem to be much tire help on here from what Ive found in past experiences.. I would but Ive never delt with one like your doing. Sorry
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
![]() Join Date: Jan 2011
Problem is the new rear is 3/4" wider per side and we dont have any info on the rim width and back spacing of the wheel you have. With out knowing the cross section width of the tire you are planning and how the rim size can affect it there are no real good answers available. Best anyone can do is maybe.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Lifting, lowering, stock? Size tire desired? Purpose of truck? Load, weight, speed? Style rim, tire? Rim diameter desired? The list goes on. I have had 33 to 35" x 12.50 on 8" rims. 275 on 7". It's how the tire looks. The best bet is a tire store. My fleetside runs a 4.5" back space on 18x9.5 but a step is narrow so if cutting inner panel to accomplish this. Go with a nice 8" all around. Pull a rim measure from drum to fender. So a 8" rim 4" back space is zero offset center of rim. Flange thickness throws off measurements too. I had same size offset rims and one set worked other rubbed.
Confused yet?
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
Thanks for trying to help, I will measure the offset later today and post it up here
#7 | |
#8 | |
![]() Quote:
Sam *My 66 s/b-st/side runs 7" wide wheels w/zero offset. 275/70/15 is all I can clear on the rear, but mine has been lowered f & r(about 3 and 2", respectively), which will make a tad of difference--but not much, as rears do bob up/down as you hit patches and bumps in the road whether dropped or not. |
