Old 01-22-2017, 02:05 PM   #1
63C20
63C20's Avatar
63 power steering conversion help needed
is there a tutorial here ?
63C20 is offline   Reply With Quote
Old 01-22-2017, 02:09 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: 63 power steering conversion help needed
Here are a couple of links that you may find useful...
http://67-72chevytrucks.com/vboard/s...d.php?t=374519
http://www.classicperform.com/power6066.htm
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-22-2017, 02:13 PM   #3
63C20
63C20's Avatar
everything i see is 67 and up, nothing for 63?
Old 01-22-2017, 03:02 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=708045
Steering box bracket:
http://67-72chevytrucks.com/vboard/s...d.php?t=332923
In the FAQ section:
http://67-72chevytrucks.com/vboard/s...55&postcount=4
Old 01-22-2017, 03:07 PM   #5
MikeB
MikeB's Avatar
Not sure about a 63 model, but I converted a 66 C10 to power steering using a 69 box and a kit like this:
http://www.classicparts.com/1960-66-...Q#.WIUBkfArJpg
I used a new Ididit steering column, so I'm not sure what you'd need to use the stock column.
Found these pictures:
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 01-22-2017, 03:07 PM   #6
63C20
63C20's Avatar
i dont understand, those are all 67 and up?
Old 01-22-2017, 03:48 PM   #7
vin63
vin63's Avatar
Are you following the links posted? Where are you seeing that the power steering conversion links are only '67 and up? Please point out the designation, because the two links I posted detail the components used for the C10 up to 1966...the CPP link takes you to an article that specifically notes the power steering conversion for 60-66 trucks.
Old 01-22-2017, 04:38 PM   #8
The Rocknrod
Moderator
Ya - wut he sat.
Old 01-22-2017, 05:09 PM   #9
vince1
I don't think they put power steering boxes on before 67 and that is why you need the later parts.
vince1 is offline   Reply With Quote
Old 01-22-2017, 08:38 PM   #10
60-66
60-66's Avatar
Are you looking for " factory power steering " or late model with new steering box ?
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 01-25-2017, 02:31 PM   #11
63C20
63C20's Avatar
can i use a steering box from a 98 suburban?
Old 01-25-2017, 02:47 PM   #12
Lugnutz65
Lugnutz65's Avatar
63C20,
I just put PS in my 1965 C10 but I have not hooked it all up yet. It's 90% done. You can see what I did on my BLOG. Scroll down until you get to the 8/30/16 entry on the main page. LINK HERE.
I bought a good condition 1974 C10 PS gear box and CaptainFab adapter plate.
I used a DD lower sleeve and rag joint from the 1974 PS box but you can buy them new from Summit Racing.
I then joined the DD lower rod to my original 1965 steering column rod using a DD universal joint I bought on eBay. My original 1965 steering rod was round so I had a machine show mill the end to the DD shape and had holes drilled in the upper and lower rod ends for the universal joint screw to capture the rods.
I also decided to shorten the column so it would be closer to the dash, but that part was just something I did for my comfort and made sense since I have a floor shifter.
I hope this helps.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 01-25-2017, 02:53 PM   #13
The Rocknrod
Moderator
Please don't say "those are 67 and up"
Old 01-25-2017, 02:57 PM   #14
63C20
63C20's Avatar
apparently you dont get it, if you look, every link you posted , if you look, it titled "67-72 trucks" so why would i belive otherwise.
Old 01-25-2017, 02:57 PM   #15
vin63
vin63's Avatar
Sure, if you have enough space to the inside of the frame, and your engineering and fabrication skills will allow for it. I say go for it and keep us posted on the set up with some photos.
The prefix URL for this forum is "67-72chevytrucks," but I'm sure you are aware that information and content for other year trucks reside on this forum.
Old 01-25-2017, 03:06 PM   #16
63C20
63C20's Avatar
so is there specific years that are easier or a perfect fit?
Old 01-25-2017, 03:31 PM   #17
63C20
63C20's Avatar
i guess im lost on what steering boxes are a good choice to use
Old 01-25-2017, 03:50 PM   #18
vin63
vin63's Avatar
I would rather see how you use a 1998 Suburban steering box. I encourage you to go that route, since apparently all of the information provided in this thread does not fit your bill or suit your needs.
Old 01-25-2017, 04:19 PM   #19
63C20
63C20's Avatar
apparently you dont know what "im lost" means. if you do don't wish to help then dont but posting just to antagonize is childish
Old 01-25-2017, 04:45 PM   #20
the_ocho
I just did a the swap today. It took me about 2 hours to install. I used a steering box, pitman arm, and pressure hose from a 1985 C30 truck. I used captinfabs bracket kit to attach the box to the frame, its an easy install. use the template to mark holes, drill them and I chose to weld the bracket to the frame to make installing the heavy box easier. To connect the box to the steering column I used the steering shaft from the same donor c30. I cut it where the round part transitions to the D shaped part and slipped that over my stock shaft and welded them together. As for a pump, I originally intended to use the 1985 c30 pump and it would have worked but the low driver side pump brackets for my SBC required a threaded boss that the 85 pump didnt have. So I picked up a pump for a 1970 camaro and used that. its worth mentioning that the 1985 pump and box use 16mm Oring style fittings while the 1970 pump uses 5/8 inverted flare. To fix this mismatch you simply swap the pressure fittings between the pumps. the metric fitting will screw into the standard pump and you now have a metric pump. This is something I don't see a lot of people mentioning on here.
Here is a link to Captinfabs bracket thread which has a ton of info.
here is a pic from that thread that shows what i mean when i say that i slipped the 1985 shaft over the stock shaft
the_ocho is offline   Reply With Quote
Old 01-25-2017, 04:47 PM   #21
63C20
63C20's Avatar
TY ocho
Old 01-25-2017, 05:12 PM   #22
padresag
pretty good man to do it all in 2 hours
ron
padresag is offline   Reply With Quote
Old 01-25-2017, 05:23 PM   #23
padresag
you didn't really express what you wanted very clearly. perhaps you should look through here to give you a clearer view of what you may want, http://67-72chevytrucks.com/vboard/s...d.php?t=646002 it will also give you most of the answers that you need
you were asked what type of conversion that you were doing whether stock or upgraded but seemed to ignore that.
ron
Old 01-25-2017, 06:09 PM   #24
vin63
vin63's Avatar
I'm not antagonizing you. Many of us, including me, tried to help by posting specific 60-66 links and/or photos of actual power steering conversions. "Apparently," none of the power steering conversion links and information that was posted earlier was to your liking (you accused us that we were only posting 67 and up info), so I would really like to see how you do a '98 Suburban steering box conversion from an engineering and fabrication perspective...I don't think anyone has done that on our trucks, at least none that I've seen photo documented.
Old 01-25-2017, 09:00 PM   #25
The Rocknrod
Moderator
If you "click" your mouse pointer to the links posted in post #4 of this thread and read - all your questions will be answered.
But first you must "read".
Are you just messing with us?
