01-22-2017, 07:34 PM | #1 |
Blazer total height with 4" lift and 33" tires?
I am currently working on a 70 4wd blazer project and doing a frame off restoration. Bought the vehicle from a shop, while they are starting body work, i took the chassis to mock up with ls/4l60e and then get everything powder coated.
My dilemma is i am not sure what lift it currently has, but would like to go with a 4" suspension lift with 33" tires, but am limited to my 7ft garage. I have done some searching here and found some evidence that it will barely clear as well as calculations based off spec'd stock height and tires. I know there is probably variation between suspension brands, but I am asking for help if any members have this setup, could do a quick height measurement to the top of the hard top!? I would appreciate it greatly so i can feel confident ordering the correct lift. Thanks, Aaron |
01-22-2017, 11:25 PM | #2 |
Re: Blazer total height with 4" lift and 33" tires?
Mine measures 6'8". It is 4" rough county lift suspension lift and 33" tires
01-23-2017, 12:33 AM | #3 |
01-23-2017, 07:11 AM | #4 |
I think the ride could be better. I'm by no means a guru on suspensions but the price was right, and I think you would have to spend a lot more to increase the ride quality to a point that it was noticeably better.
01-23-2017, 12:49 PM | #5 |
Anyone else lend a hand? Could use a couple more measurements on other to increase my confidence level!!
01-23-2017, 01:35 PM | #6 |
I just measured mine. It's a 70 also with 12.5X33", Softopper and no lift. It's 6 foot 4" (74")
01-23-2017, 02:06 PM | #7 |
My opening in the workshop is 76 1/2" 4" lift with 31" tires. truck goes out and in
[url=https://flic.kr/p/MrhdhV]
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
01-23-2017, 08:42 PM | #8 |
01-23-2017, 10:34 PM | #9 |
Dan was using the "metric" inch up here in Canada.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
01-23-2017, 11:01 PM | #10 |
Carpe manana
I've got a 4" lift and 33's on my green blazer and it clears a 7' door and measures ~79" tall. On day I'll downsize the lift - too tall for my liking and I'm worried my wife will tear off the gb door when she scrambles inside.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
01-24-2017, 09:10 AM | #11 |
My '70 is also at 79". But,.. I have 35's, 4" front rancho and 3" rear blocks. So feel more confident?, Or more confused?
01-24-2017, 09:31 AM | #12 |
01-24-2017, 03:45 PM | #13 |
Yep, thanks everyone, feel pretty confident, going to pull the trigger on the 4" leaf springs...if too tall i guess i can load it up with some sand bags, lol
now just need to decide if i want to save a few bucks and go rough country or shell out more for a softer ride! |
01-24-2017, 06:04 PM | #14 | |
01-24-2017, 06:21 PM | #15 |
just factor this in...because I did not
4 inch lift is a true 4 inch lift OVER stock height......so if its has sagged a inch or so you may go up more than 4 inches..... my surburban...I did a 4 inch lift and 35 tall tires.....and didn't factor in for the sag
1972 Cheyenne Super..owned since 1978 1972 Surburban 4x4 1972 Cheyenne 4x4 3/4 ton.....sold 1972 Cheyenne 2wd...named Death Row |
