Old 01-22-2017, 07:49 PM   #1
white71chevy
white71chevy's Avatar
Stock replacement radiator with extra port?
Hey everyone haven't posted in a while but I started doing a ls swap in my 71 c10 that had a 350 th350 combo in it however I was looking at radiators for it and noticed that oreillys replacement one has an extra port that I don't know what it is for. I thought I would see if anyone on here could tell me what it is for and if I could use that port for the steam port on the ls?
71 c10 with a 305. new dd wohoo
1956 chevy bel air hard top with a 327.
1998 honda passport V6 old dd.
white71chevy is offline   Reply With Quote
Old 01-22-2017, 08:13 PM   #2
dmjlambert
dmjlambert's Avatar
Re: Stock replacement radiator with extra port?
On my new Engineered Cooling Products radiator I have the same thing in that position and the website says it is a heater return port with plug.
dmjlambert is offline   Reply With Quote
Old 01-22-2017, 08:16 PM   #3
white71chevy
Hmm so could it be used for the steam port then?
Old 01-22-2017, 09:14 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Steam port? I dunno, have not heard of that. As posted above, on my K20 that nipple is for the heater return hose. If a steam port dumps hot water / steam into the coolant then it should work for that.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 01-22-2017, 09:19 PM   #5
Jason Banks
Jason Banks's Avatar
I had a truck that had one of the heater lines hooked up to that location on the radiator.
Jason Banks is offline   Reply With Quote
Old 01-22-2017, 09:28 PM   #6
FirstOwner69
FirstOwner69's Avatar
From my observations...
On the earlier trucks, such as my '69 with a 350, the heater return hose ran to a nipple on the right front corner of the intake manifold. Later trucks (maybe '71s and '72s) had the return line run to a port on the radiator as shown in your picture. Perhaps someone with more info can chime in.
FirstOwner69 is offline   Reply With Quote
Old 01-22-2017, 09:45 PM   #7
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Stock replacement radiator with extra port?
The extra port is a heater core hook up. Depending on if it had AC are not the heater return went to the radiator on some models.
Yes you could use it for a steam port hook up if you can get the right reducers for the hose fitting.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-22-2017, 11:12 PM   #8
darrellyates
I used it for the "steam port" on my 5.3 ls swap some years ago, and plan on doing the same. Mine ran perfect off that port, got some brass adapters down to a hose nipple. Worked fine.
darrellyates is offline   Reply With Quote
Old 01-23-2017, 02:31 AM   #9
white71chevy
Awesome thanks everyone for the replies being able to use that will make this whole ordeal a lot easier. From some of your responses tho it seems I am calling the vent the wrong term, what should it be called then was always told to make sure it was hooked up to prevent overheating or something along those lines.
Old 01-23-2017, 01:25 PM   #10
Andy4639
Old member
Andy4639's Avatar
Port, vent it's all good the same thing.
Just a word on when you fill the motor up with water take the steam port's on the top of the motor loose until you have water coming out then reinstall them. It will be a big help on this. You don't have to take them all the way out but back them off enough to see the water start seeping out. It gets all the air out of the system.
Old 01-23-2017, 03:57 PM   #11
white71chevy
Alright thanks for the info I'm sure it'll come in handy.
Old 01-23-2017, 04:53 PM   #12
Andy4639
Old member
Andy4639's Avatar
It took me forever to vent mine until I was told! It vented out the ports and I never had any more problems.
Old 01-23-2017, 08:28 PM   #13
demian5
demian5's Avatar
on 73 and up square bodies it is used as heater return. I'd use it for that if I had one.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 01-23-2017, 11:33 PM   #14
1972RedNeck
1972RedNeck's Avatar
According to the '72 service manual, that is the heater return port on automatic trucks. On manual trucks, the heater returns to the intake. A/C or not.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 01-24-2017, 02:06 AM   #15
stsalvage
Scrapper 1
stsalvage's Avatar
I hate plastic radiators.They give you a few years of good running But they get eaten up to fast.If you can save the side tanks on your old brass copper radiators do it.They last longer plus when you truck sits for 2-3 years they tends to just need to be rodded out and cleaned and flushed for 100.00.Plus they send to take pressure better then plastic dose over time.Nothing compares to copper and brass Plastic just give it time it will leak clog up or crack
stsalvage is offline   Reply With Quote
Old 01-24-2017, 03:35 PM   #16
67 chevelle
67 chevelle's Avatar
Agree
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
