LMC tail light wiring
Hey all,
I bought new tail light assemblies from LMC and they have included wiring. The left side has a yellow wire, a brown wire and another brown wire with a spade connector on it. The passenger side has just a green wire and a brown wire. Does the left side brown wire with the spade connector run to the ground or does it need to be connected to the passenger side? Thanks in advance... |
Re: LMC tail light wiring
The lamps are "Case Grounded", No ground circuit.
Yellow.....Left Turn/Brake Green.....Right Turn Brake Brown.....Running Lamps, Splice the left to the right. |
Confucius Say...... License plate light
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Tail light wire and brake/turn wire.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
