Coil Spring Length
73-87 chevy c10 2wd shortbed stock not bagged or lowered, can anyone tell me what the length of the front coil spring (top to bottom) when the truck is at ride height and full weight of truck is on it?
![]() Join Date: Jul 2000
Re: Coil Spring Length
Moog #6452 is shown as the "standard" spring replacement for 1982 C10.
Free height: 13.64" Installation height: 10" Rate: 843 lbs/in Here's a Moog #6454 HD spring: Free Height: 13.61" Installation height: 10" Rate: 1060 lbs/in But none of the above really helps you. A better measurement might be "fender lip to center of spindle" on a stock C10. But that would vary with age of spring, engine weight, etc. FYI, the only GM specs I could find are "Springs @ Ground". For the standard GM spring it's 1475 lbs each. For HD spring it's 1750 lbs each.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
