how much pulling weight?
Hey All,
I have a 1971 chevy c10 with 350 engine th350 automatic transmission can i pull a 3800 pound boat and trailer with it safely? thanks |
Re: how much pulling weight?
bump
Id say so yes
thanks
![]() Join Date: Jan 2015
The truck was rated from the factory to pull 6000 lbs so you will be fine!
1969 C20 Suburban "Rez Dog" Rebuild America one testicle at a time. US Army 1977-1979 12B Combat Engineer US Navy 1979-1983 Gunners Mate Guns (GMG) NRA Life Member Unrestrained Children in back seats cause Accidents. Unrestrained Accidents in back seats cause Children. |
![]() Join Date: Oct 2011
Yes...but:
-You'll need a proper correct frame hitch. -You'll need a trailer brake system....the truck brakes won't be enough on their own (or legal). Also recommended: -Add a transmission cooler if you don't already have one and have your trans serviced prior to any significant amount of pulling/trailering. -Upgrade the radiator to a minimum 3 row/core radiator (a 2 row/core probably won't cut it unless you tow short distances and not uphill). Do you know if your rear diff ratio is a 3:73 ratio...or the stock V-8 ratio of 3:07? Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
Here is the 1969 towing capacities, from the dealer manual: http://bit.ly/2kkD2pN
#8 | |
#9 | |
That sounds like a load I'd feel pretty comfortable pulling with your truck. I towed a VW type 2 bus (almost exactly 3,000 lbs.) on my single-axle 14 ft. trailer with the 'Burb and the only real shortcoming was the 4-wheel drum brakes that need new shoes badly. Just don't tailgate and make sure your trans. stays cool, otherwise it's well within the realm of what these trucks were built for.
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
Question,when did it become illegal to tow without trailer brakes?? Serious question with no offense meant.
As far as the weight of the boat, I wouldn't hesitate a minute to tow it. I have pulled some heavy loads with mine and no regrets. Sounds like you covered the brakes and cooling system so no worries. Trans cooler is a good addition but don't let it stop you from using your truck. I have not added one yet and no issues
1972 GMC C20 Custom Camper 350/TH350 |
Do yourself a favor and take a good look at your brake lines and rubber hoses going to your front brake calipers....
#13 |
I'm not sure of all the U.S laws state by state....in terms of (trailer) brakes.
In Canada, I believe anything over 1500 lbs, by law, has to have its own brakes and thus you have to have a trailer braking system to activate them. It's worth doing a quick check on your particular state to see if anything like that exists in the U.S. That said...on a personal note I would never tow anything with a 1/2 ton truck that weighed over 1500 lbs without trailer brakes....unless I was towing on the flat in the country a few miles. (Google B.C or British Columbia and you'll see why...lol) All good Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 Last edited by Coley; 01-25-2017 at 12:01 PM. |
#14 |
You can look up state trailer towing laws on trailers.com. Here is a link to the Florida laws: http://trailers.com/state-laws/florida.php. You will need trailer brakes to tow that 3,800 pound boat.
#15 | |
![]() Quote:
Most 1/2 tons weigh close to 4000 lbs so 40% of that gross vehicle weight would be 1600 lbs max. in terms of an allowable trailer weight. It's not that it can't be done...but if you get into trouble you are out of luck not only for safety, but also for your insurance and perhaps if you hit someone due to not being able to stop. C.
#16 |
I'm glad this thread came up, I am finishing my '71 C10 up with all new parts or rebuilt parts so the base truck is perfect. I tow my 29' camper with an Expedition that empty is 6200 lbs, loaded up another 1000 so 7200 lbs. With appropriate frame mounted hitch, load bars, trailer brake controller how do these trucks do with campers. I don't travel far, usually no more than 40 miles .
#17 | |
#18 | |
![]() Quote:
You don't see a lot of (professionally built) trailers these days over 1500 lbs without trailer brakes...unless they are home made or very old. 1600 lbs is not really a joke behind a vehicle if you are coming down a long (B.C) hill or mountain. To my recollection the 'old school' rule of thumb is to try to say with a trailer weight that is about 1/2 of your car/truck's weight....noting that a trailer braking set up changes this up in a good way. You should check with D.O.T regulations as relating to Manitoba....might be different, or not. ...all of this tho' begs the question...why would anyone want less braking ability instead of more, particularly when 3-4 tons (or more) worth of momentum is underway at 50 mph? Its not like a trailer brake is a big deal or even expensive. Personally, I like the trailer brakes I have on our small camping trailer (approx. 1800-2000 lbs)....I just touch those from time to time and everything settles down coming down a hill. C.
#19 | |
#20 |
Yep I have my doubts, motor is there but with no stabilizer bars and a lighter truck it is pushing it. I was curious if folks are towing campers with these and what they experienced though, it seems like the 1/2 tons in this age range are a little light as far as sturdiness and stability but that goes for most vehicles from that era.
