Old 01-24-2017, 12:57 AM   #1
Metalaroundstone
question about welding bedsides
When I took apart the bed of my 66 fleetside, each bedside was welded to the rear cross member in two places. I was planning of re-welding everything in the same way when I put the bed back together. But now that I am putting it together, all nice and shiny, I am questioning whether or not it is necessary to re-weld. Anybody have any experience with leaving off these welds? Does it comprimise the stability of the bed?
Any recommendations to weld or not?
Metalaroundstone is offline   Reply With Quote
Old 01-24-2017, 10:15 AM   #2
bpmcgee
bpmcgee's Avatar
Re: question about welding bedsides
My '60 did not have the bed sides welded to the cross members at all.
B
bpmcgee is offline   Reply With Quote
Old 01-24-2017, 02:03 PM   #3
61K10
61K10's Avatar
I didn't re-weld mine. you can keep an eye on the bolts so they don't loosen up. Should be fine.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 01-24-2017, 04:58 PM   #4
oem4me
It's my understanding that GMC's did not come welded. That's a chevy thing. So I'm guessing it would not be a problem leaving it alone.
Old 01-24-2017, 10:30 PM   #5
Metalaroundstone
That is interesting. I wonder why chevy added the welds. Did you add the welds when redoing any of your trucks?
Old 01-25-2017, 12:09 AM   #6
oem4me
Me personally, no. I don't own any GMC's, and nothing I presently own has been redone.
Old 01-25-2017, 10:15 AM   #7
60-66
60-66's Avatar
Chevy did this before the bed was painted. All Chevy beds were painted as an assembly. Most GMCs were, parts painted individually in finished color, then assembled . Ive done several this way freshly painted , no welds , you will be fine doing it that way. Tailgate needs to be installed before you finish tightening all the bolts for rear alignment of the bedsides.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 01-26-2017, 11:59 AM   #8
Metalaroundstone
Thanks for the replies. Very helpful. I will see how it goes without the welds. I can always weld it later if it is not strong enough.
