Old 01-24-2017, 01:45 PM   #1
ch3vynoob
heater hoses help!
Ok i have a 1960 apache that was put onto a 1978 blazer frame. the blazer frame has a sb350 in it and the apache has the deluxe heater system. The previous owner blocked off the tube in the picture. I am wondering does the blocked off tube go into the top or the bottom of the two tubes on the heater? Also where does the heater hose from the heater plug into on the engine?
Is having that hose blocked off the way it is bad for the pump? Just wanting to make sure i dont hurt the motor any more than it has been.
ch3vynoob is offline   Reply With Quote
Old 01-24-2017, 03:05 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: heater hoses help!
http://67-72chevytrucks.com/vboard/s...d.php?t=726885
Old 01-24-2017, 03:12 PM   #3
ch3vynoob
Thank you but i dont have a spot on the pump to plug in any hoses. I am confused as what to do with that.
Old 01-24-2017, 03:20 PM   #4
The Rocknrod
Moderator
It's there. You have a pipe plug in place instead of a pipe nipple that you need to install.
Old 01-24-2017, 04:48 PM   #5
ch3vynoob
Ohhh ok Thank you! i havent ever worked on this motor so im just learning. But thank you for your help!
