Old 10-14-2003, 08:31 PM   #1
dropped_71chevy
alternator bracket w/o accessory holes
I bought a set of camel humps with no accessory holes and I need to find a simple alternator bracket for the passenger side that will bolt onto water pump/intake with a short water pump. Any help would be awesome
thanks guys
TT
dropped_71chevy is offline   Reply With Quote
Old 10-14-2003, 08:48 PM   #2
bigjimzlll
bigjimzlll's Avatar
http://www.alangrovecomponents.com/
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 10-14-2003, 09:06 PM   #3
cableguy0
you could always make a template from your old heads and drill the holes yourself
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 10-16-2003, 07:50 AM   #4
Ed ke6bnl
Re: alternator bracket w/o accessory holes
thanks guys
TT
I have the camel hump head no accesory holes I got the two pieces sold at PAW and many other places that bolt to the first two "header" bolt and then a piece that bolts to that for the alt monunt and a bar for the tensioner monunted to the water pump with a spacer. all chrome for about $25 dollars. Need some tweeking for it to all work . Ed ke6bnl Short water pump for me
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
1948 F3 ford pu
1949 F1 stock V8 flathead 3 on floor
1950 F1 pu street rod
1948 F6 Ford Dually/350sbc no bed stock trans&rear
1972 El Camino 4" chop
1953 Chevy 3100 2b daily driver
1970 SB 4X4 400ci 6in lift
Ed ke6bnl is offline   Reply With Quote
Old 10-16-2003, 09:37 AM   #5
tom hand
CCRider
tom hand's Avatar
Been there, done that. There are two problems with drilling the holes. 1. the bosses are not there for the holes and the head is not machined flat on the end. 2. You will drill into the water jacket.
That being said, I have done it and put sealer on the bolts and it worked. You will have to shim the braket to get the pullies to line up
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
