p/s pump braket
so i just acquired a ps pump for my conversion, this is the pump i have pictured.
now, #1 pic shows the bracket piece i need thats missing. #2 shows a part missing, i cant find a pic of what it looks like?? |
Re: p/s pump braket
#2 solved... #3 shows a part missing, i cant find a pic of what it looks like, it bolts up to the ramhorns end
Re: p/s pump braket
# 2 is called a long water pump but looks like you figured that out ... #3 is for an alternator bracket NOT power steering pump
![]() Join Date: Oct 2007
Re: p/s pump braket
Try Alan Groves Components (Google search). Nice quality brackets that will work with any combination of exhaust, PS pump, and water pump.
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: p/s pump braket
If you're using a rams horn style of exhaust manifold, you will have to trim off the alternator mount to be able to use that bracket for the power steering pump. The main issue here is that all trucks '72 and earlier originally came with short water pumps. What you are working with there is a long water pump. That is why some parts work and others do not without modification. You will need a long water pump with a threaded hole in that spot and not the pump with the smooth bore.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 01-25-2017 at 12:37 AM. |
