250 4 barrel throttle
what are you guys using for throttle cable/rod on a 250? i would like to use the stock set up as much as possible.
any good write ups on how to make own fuel lines? i am looking to make something out of metal fuel lines but never done it before. |
Post Whore
![]() Join Date: Mar 2013
Re: 250 4 barrel throttle
I used the lokar pedal and cable system.
Numbers Pedal: https://www.summitracing.com/parts/lok-bag-6149 Cable: https://www.summitracing.com/parts/lok-tc-1000u Carb Mount: https://www.summitracing.com/parts/lok-srk-4000 Just get yourself a good napa tubing bender and a piece of fuel line to practice on. I never did it before either, not as bad as it seems. ![]()
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
I first ran across a throttle cable in a 65 Ford P/U. I think they also used them in later years in both cars and trucks. You might keep quite a few dollars in your pocket by cruising the junkyards for a complete setup.
Post Whore
If you don't wanna use F%%D parts I believe you can use a 70's chevy throttle pedal and cable as well. If I remember right, Ta2Don did that with his build.
I use a pedal from a 71 c10 and lokar cable
65c10 43,000 original miles ,230 stovebolt,powerglide,3" drop spidles 3" drop springs w/ half coil cut and 5 drop springs in back with 1 1/2 blocks... c notch soon to add hei offy 4 v intake and holley 390 ![]() |
I used the original bell crank mounted sideways on a bracket that mounts to the 2 rear studs on the Edelbrock 4bbl carb. Works nice and smooth for me.
