01-25-2017, 01:53 AM | #1 |
Should it be welded?
I am replacing my floor pans and rocker boxes. I noticed the connection between the underfloor brace and the firewall brace is not welded on either side. Is there a reason this area is left to "float" or is it supposed to be welded? This is in front of the front floor body mount.
01-25-2017, 08:44 AM | #2 |
Re: Should it be welded?
When I redid my 1972 Jimmy. Those two pieces showed signs of five or six factory spot welds. The passenger side of mine, all six spot welds were broken and I had to plug weld them back together. After doing this it really made the fire wall alot more ridge.
01-25-2017, 10:18 AM | #3 |
my spot-welds were broke off on mine as well
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
01-26-2017, 05:39 PM | #4 |
I need to check mine now! Anything to stiffen up the tub is a plus in my book.
01-27-2017, 01:52 AM | #5 |
Thanks for the input guys...I wanted to check before I melted them together.
