Old 01-25-2017, 03:06 AM   #1
Bhelton
Bhelton's Avatar
71 5 lug posi 12 bolt and front brake parts
As title says 71 C10 rear axle 5 lug posi unit and 5 lug rotors, spindles and calipers. . Rotors calipers and bearings have 100 miles on them, planning on a dually conversion so I won't need any of it. Price is 850 or best offer
Bhelton is offline   Reply With Quote
Old 01-25-2017, 03:08 AM   #2
Bhelton
Bhelton's Avatar
Re: 71 5 lug axles and front parts
Pic of spid and truck
Old 01-25-2017, 04:07 PM   #3
Jrainman
Jrainman's Avatar
Would like to know the Gear Ratio of the Posi unit ???
Jrainman is offline   Reply With Quote
Old 01-25-2017, 04:20 PM   #4
Speedracer39
Speedracer39's Avatar
Hard to see spid is this a leaf spring rearend
Speedracer39 is offline   Reply With Quote
Old 01-25-2017, 04:46 PM   #5
Bhelton
Bhelton's Avatar
Coil spring
Old 01-25-2017, 04:48 PM   #6
Bhelton
Bhelton's Avatar
I'll have to look ok and see, my guess being a original 6 cylinder and 3 speed would be it's a 3:73 but may be higher or lower
Old 01-25-2017, 09:33 PM   #7
Speedracer39
Depending on what gear ratio is but if you decide to sell posi separate I may be interested
Old 01-25-2017, 10:19 PM   #8
zicc1835
zicc1835's Avatar
and if you break it up i would be interested in the complete rear brake setup
zicc1835 is offline   Reply With Quote
Old 01-26-2017, 02:42 PM   #9
Bhelton
Bhelton's Avatar
I'll check ratio this weekend, however I will not disassemble rear axle to remove the chunk. If I do the price for chunk is same as buying the entire unit.
Old 05-21-2017, 05:15 PM   #10
FL71C10
do you still have this rear end?
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 05-24-2017, 09:45 AM   #11
panhead59
If u wanted to sell the brake parts to zicc1835, I would be very interested in the rest of the rear. I am close (Roanoke, Va.) so p/u would not be a problem. Guess I better ask- I would be putting in a 68, same width etc.?
panhead59 is offline   Reply With Quote
Old 05-24-2017, 12:43 PM   #12
Bhelton
Bhelton's Avatar
Sorry to respond late but I sold entire truck
