Need help with steering column turn signal
Hey guys, did a search and couldn't seem to find the info I need. I'm looking at my turn signal assy and am missing what is circled in red. Can I buy this part separately or do I need to replace the whole assy?
![]() Join Date: Oct 2009
Re: Need help with steering column turn signal
Pretty sure you have to buy a whole ts switch unless you can source that from a part-out ts switch.
Old member
You have a later model steering column per your picture. it has the later model 4 way flasher button.
Here is the break down for the stock column. You can take the turn signal out of the steering column and see if it has the ring. Are try taking the cap out of yours and stretch the spring in it. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I think you need the complete turn signal switch,I bought mine from( truckandcarshops)...
Thanks guys. Looks like I'll have to buy the whole thing.
