01-25-2017, 06:22 PM | #1 |
Needing a driveshaft
Was wondering what my options are for a driveshaft for my new 5.3 swap in my 1971 SWB 2 wheel drive C10. Before you say mine will work, understand that the original shaft was shortened when it had the S-10 5 speed in it, making it to short now. I know an original shaft would be best, but what other oem shafts will work. I'm trying to make this easy on my wallet, so finding a used shaft and having it shortened and balanced would be the most cost efficient, since a new built shaft is between 3 and 400 dollars. Please help guys, I need a shaft asap so I can do my exhaust and get this thing back on the road. Thanks
01-25-2017, 08:45 PM | #2 |
Fabricate till you "puke"
Re: Needing a driveshaft
There are too many variables on that ls swap, (as far as engine position). I suggest that you slide the slip yolk into the trans (to the bottom), mark it with a sharpie, then slide it out 3/4" (with the weight on the wheels). Then you can bolt the rear u-joint to the diff, & measure center to center on the caps to get the lenght that you need for your combo. After that, you can hit the boneyards, & find something to work for you (shorten & balance). best of fun,longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
01-25-2017, 09:42 PM | #3 |
like crazy stated above, get motor, trans and rear end in their final position then measure from yoke u-joint centerline to yoke u-joint centerline.
i got lucky and found one at a local salvage yard that was the exact length I needed. you can always buy one a bit long and have it shortened. |
01-26-2017, 10:49 PM | #4 |
Nobody will believe this, however I got a boneyard 5.3/4L60E out of 2004 Tahoe 2WD. I even picked up the driveshaft (just to get the trans yoke). It was the exact correct length. All I had to do was have the rear connection changed for the differential, and I could have used it. Due to extreme lowering, and the overall size of the factory shaft, I wound up making a new one. However, the 2004 Short 2WD Tahoe one fit my '68 SWB. Of course, that was switching out the carrier bearing for a one piece driveshaft as well. Hope that helps....
01-26-2017, 10:56 PM | #5 |
However, the 2004 Short 2WD Tahoe one fit my '68 SWB. Of course, that was switching out the carrier bearing for a one piece driveshaft as well. Hope that helps....[/QUOTE]
01-29-2017, 08:41 PM | #6 | |
02-01-2017, 06:41 PM | #7 |
What exactly was changed to make the driveshaft work? Does the u joint from the Tahoe fit on the rear differential? Any help is appreciated
Jz |
02-01-2017, 06:54 PM | #8 | |
Hope that helps! |
02-01-2017, 08:59 PM | #9 |
I think I understand. I'm not trying to go with a custom shaft so in a sense I just need and adaptive u joint that will fit the tahoe end of the driveshaft and the differential C10 connection. Do you happen to know the part number or specs I need to look for on an adaptive u joint?
Thanks again! I appreciate your help Jz |
02-01-2017, 09:12 PM | #10 |
[QUOTE=rctrooper1;7845677]I think I understand. I'm not trying to go with a custom shaft so in a sense I just need and adaptive u joint that will fit the tahoe end of the driveshaft and the differential C10 connection. Do you happen to know the part number or specs I need to look for on an adaptive u joint?
Thanks again! I appreciate your help Sorry, I don't remember the sizes. You just have to measure either the old U Joints, or there are instructions on how to measure the yoke on-line. Just google "how to measure U Joint" and you'll get instructions. They make them for all different sizes, I was shown at the drive shaft shop, Clinard's in Nashville. Since I wanted the clearance, I had one made. Wasn't expensive. I'm sorry, I don't remember the sizes. Someone has to have a better memory than I do for that. Hope I have been some help even if I can't remember the sizes. |
02-01-2017, 09:14 PM | #11 |
No problem. Thanks again!
Jz |
02-06-2017, 06:49 PM | #12 |
I have done many conversion joints over the yrs.... Dont ask the parts house guy to figure it, take the 2 joints to the drive line shop & show them what you need to swap to They will set you up with the info/proper parts....Longhorn
02-28-2017, 08:34 PM | #13 |
Finally got the 2004 DS in place. Used Moog 372 combination U joints. Perfect fit.
Thank you all for the help! Jz |
