Old 01-26-2017, 02:42 AM   #1
Jcfcamaro
Jcfcamaro's Avatar
72 Am/FM radio
Does anyone know or have a wiring diagram to hook this radio up to test it. It has a plug in the rear with 3 spades.
Jcfcamaro is offline   Reply With Quote
Old 01-26-2017, 05:58 AM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: 72 Am/FM radio
One is positive the other two are for the speaker. I think the diagram is stamped into the metal.
brad_man_72 is offline   Reply With Quote
Old 01-26-2017, 02:48 PM   #3
Jcfcamaro
Jcfcamaro's Avatar
Re: 72 Am/FM radio
I'm not seeing anything on it?
Old 01-26-2017, 05:43 PM   #4
FirstOwner69
FirstOwner69's Avatar
Re: 72 Am/FM radio
It uses the same wiring harness as the AM radio. The picture below may help. The red is positive. The black and green go to the speaker (you can see speaker "remnants" on those wires in the picture).
FirstOwner69 is offline   Reply With Quote
Old 01-26-2017, 08:04 PM   #5
Jcfcamaro
Jcfcamaro's Avatar
Re: 72 Am/FM radio
If the back of the radio was in front of me with the plug on the right side. Which side does the hot wire go? Far left or far right?
Old 01-26-2017, 09:23 PM   #6
FirstOwner69
Re: 72 Am/FM radio
If a picture is worth 1000 words are 2 pictures worth 2000 words?
Old 01-26-2017, 10:39 PM   #7
Jcfcamaro
Jcfcamaro's Avatar
Re: 72 Am/FM radio
Thanks, Maybe 3000
Old 01-26-2017, 11:13 PM   #8
70shortfleet
70shortfleet's Avatar
Re: 72 Am/FM radio
Don't loose that AM filter that has fallen down into the the front of the radio! I can see it through the window, they are hard to come by.
70shortfleet is offline   Reply With Quote
Old 01-26-2017, 11:19 PM   #9
FirstOwner69
Re: 72 Am/FM radio
X2
Good catch!
Old 01-27-2017, 02:15 AM   #10
Jcfcamaro
Jcfcamaro's Avatar
Re: 72 Am/FM radio
Yeah. I noticed that also. I have it out sitting on my work bench.
Old 02-01-2017, 11:16 AM   #11
Jcfcamaro
Jcfcamaro's Avatar
Re: 72 Am/FM radio
Well, I got it hooked up and it doesn't seem to have any sound coming out. Might be my antenna, but I can get some static on the speaker when turning it on and off but that's it.
Old 02-01-2017, 12:59 PM   #12
70shortfleet
Re: 72 Am/FM radio
Did you run a ground to the case when testing?
Old 02-01-2017, 01:25 PM   #13
Jcfcamaro
Jcfcamaro's Avatar
Re: 72 Am/FM radio
Yes
Old 02-01-2017, 03:02 PM   #14
tristan
Re: 72 Am/FM radio
Time to send it off to Joe Cilluffo in SC for a makeover, he is reworking my 1971 AM/FM now and does great work.
tristan is offline   Reply With Quote
Old 02-01-2017, 03:32 PM   #15
FirstOwner69
Re: 72 Am/FM radio
Did you ground the antenna. I think that also needs to be done. Maybe someone can confirm. They normally ground to the body.
Old 02-01-2017, 03:34 PM   #16
Jcfcamaro
Jcfcamaro's Avatar
Re: 72 Am/FM radio
Did not ground the antenna. What does the guy in SC get to restore a radio. Ballpark
Old 02-01-2017, 05:11 PM   #17
flaa1a
flaa1a's Avatar
Re: 72 Am/FM radio
Around 350 bucks?
http://www.joesclassiccarradio.com/services.html
flaa1a is offline   Reply With Quote
Old 02-01-2017, 08:06 PM   #18
tristan
Re: 72 Am/FM radio
It's about $200 for a comprehensive clean and check and scales up from there if he has to replace innards. He can also send your faceplate and trim pieces off to be replated at additional expense although his guy is slow and expensive. He rebuilt the Delco AM and sold me a replacement speaker for my Jimmy and did a great job; I look forward to getting my AM/FM back to see how things turned out.
Old 02-01-2017, 08:10 PM   #19
Jcfcamaro
Jcfcamaro's Avatar
Re: 72 Am/FM radio
Looks nice
