66 c10 back up lights help needed
my 66 has back up lights installed but no wiring at all.
it has an Ididit column with a backup switch installed on it at the bottom. need help on where to route wiring and where to hook up under dash. thanks Allan |
Re: 66 c10 back up lights help needed
Just to get this started and my info could be wrong because it has been a couple years since working on mine so just some questions rather than answers.
Is there a spade on the fuse block for back up lights? Is there a free wire for back up lights in the ribbon of wires running along the frame rail to the back? |
![]() Join Date: Jan 2011
Check the pin on the column for power with shifter in reverse and the ignition on. If it has power on it I would run a new wire to the lights in the back. The lights should have a single wire coming out of the so you need to make sure the cases have a good ground path.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Third photo post #4 top wire on right (one with NO fuse JUST above where it says B.U. LPS.) is where power comes from for BU light switch on column .... http://67-72chevytrucks.com/vboard/s...d.php?t=423593
