Old 01-26-2017, 10:23 AM   #1
AnobleL74
66 c10 dome light wiring help
my 66 has dome light installed and wires running to under dash and they are not connected to anything.
need help on where to route wiring and where to hook up under dash.
thanks Allan
AnobleL74 is offline   Reply With Quote
Old 01-26-2017, 12:24 PM   #2
PGSigns
PGSigns's Avatar
Re: 66 c10 dome light wiring help
It ties into the headlight switch. Go to the FAQ section and scroll down to the wiring section and get the diagram. Should allow to find the hook up under the dash.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-26-2017, 02:12 PM   #3
jtrichard
Post #2 orange and white wires (at bottom of fuse block) are for dome light http://67-72chevytrucks.com/vboard/s...d.php?t=423593
jtrichard is offline   Reply With Quote
Old 01-26-2017, 11:39 PM   #4
rvrfoot
I just did mine it plugs into the fuse panel. The wire runs along the rocker up of the inside of the door.Then to the light.
rvrfoot is offline   Reply With Quote
