turbo LS build
Ok my question is has anyone here turboed there LS swapped c10?
When I did my LS swap I added the sure fit vintage air setup. Now I'm looking to add boost and I'm having a hard time deciding how to run my piping and where to place my intercooler. My a/c compressor is mounted on the top passenger side of my motor and the condenser is in the way of mounting my intercooler center of my core support. if anyone has done this setup please share pics and info. |
Re: turbo LS build
The intercooler mounting is simple enough. Make some brackets that attach to the core support that the intercooler then bolts to. Some 1" steel tube and 1/8 plate should do it.
Pipe routing for the usual passenger side turbo mounting is trickier with the compressor up top. Post some pics of your engine bay? Maybe you can get the downpipe out under the compressor or run on top of the inner fender until it's past the compressor. There's a few turbo setups on the board here. There's 2 search function up at the top of the page. I prefer the one right below your user name instead of the grey box one. The grey box lists the results like a google search, I prefer the other that uses the forum software search feature and the layout it produces. Just type turbo in either and browse the results for ideas. Searching "turbo c10" on youtube will get you some results too. |
#3 | |
Re: turbo LS build
Re: turbo LS build
Re: turbo LS build
Beautiful engine bay.
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too Cream Puff - LS'd Square - Slow going on the back burner Tripple Threat - 3 Wrecks for the price of one build thread Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered. |
Post Whore
![]() ![]() Join Date: May 2015
Re: turbo LS build
That's a very nice engine bay moretoy..
Re: turbo LS build
Sorry I mean the dryer is in my way. The only thing I can think of is making new lines and relocate it. I have done a lot of google searches and everything I have found are none a/c trucks.
Re: turbo LS build
I've been waiting for someone to try a hotside kit for a 5.3 truck. Looking at routing I think it would be close.
67 C10 Choppin block backhalf KP Components front dropmember US Mags Rambler 20s |
Re: turbo LS build
This may help..I did have to have one line made..
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
Re: turbo LS build
Woops, wrong picture. I'll have to go take one.
Boosted Member
Re: turbo LS build
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
Re: turbo LS build
