Tilt column, anyone recognize what it might be from
This is the tilt column in my truck. I want to put a gear indicator on it and the one I've got doesn't fit so I'm guessing this is not a stock column. PO gave me no info on it. Anyone recognize what it might of came from? Any help us appreciated
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 Last edited by hdff; 01-26-2017 at 06:46 PM. |
#2 | |
![]() Join Date: Oct 2011
Re: Tilt column, anyone recognize what it might be from
C.
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
Sorry they wouldn't load from my iPad so I had to jump over to my phone... here are the pics
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
![]() Join Date: May 2010
Column looks like a correct tilt to me. Can you post a picture of the gear indicator housing looking at it from the driver's seat?
I think this is what your asking to see. Here is the indicator I'm trying to use
'doesn't fit'.....hmmm. In what way?
That tilt indicator should work but you are going to have to remove the (chrome?) indicator housing off of the column to install it (held on by 2 small phillips screws) Once you have the housing removed, slide the indicator into the lower shifting slot on the column. Then tilt the housing to get the upper pointer part inserted and 'locked' into the upper housing and carefully put it back on top of the column housing....then re-install the 2 phillips screws and you should be good to go. I also put a small dab of lubricating oil on the lower tab before I put it in the column. If you have been trying to install it without removing the upper housing....that is probably the problem. Coley
By indicator, do you mean the white pointer? if so, here's a picture of mine installed. I found it easiest to place the "hook" under the housing before screwing it to the column.
From looking again at the pictures in your first post, it appears that part of a previously installed pointer is painted black and still in the cavity in the shift collar. You'll need to pull that out.
#9 | |
UPDATE: First owner was right, old pointer was broke and painted. Pulled out the broken piece and now looks like it will work. I'll try to get the new one in tomorrow. I've learned the hard way that it's always better to ask than mess something up... Thanks everyone
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 Last edited by hdff; 01-26-2017 at 08:58 PM. |
The chrome indicator looks like a standard '67 column indicator housing.the tilt column could be from a truck or Van.
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time" ![]() “Serious Black” my 1971 Short Bed Fleetside Sold to an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten” |
