01-26-2017, 09:17 PM | #1 |
Do These Two Wheel Dimensions ....
...put the tire in same position in fender well? All the measurements are the same except
one wheel has neg12mm off-set with 4" back space..the other has 0 off-set with 4.50 back space..If not, which wheel will put more tire toward the curb? |
01-26-2017, 09:21 PM | #2 |
Re: Do These Two Wheel Dimensions ....
depends on the wheel width
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
01-26-2017, 09:25 PM | #3 |
wheel drawing with -12mm off-set with 4" back space..If you move the mounting plate to 0 off-set won't that give you 4.50" back space?
01-26-2017, 09:31 PM | #4 |
01-26-2017, 10:09 PM | #5 |
The one with less backspace.
01-26-2017, 10:13 PM | #6 |
I misunderstood your question. The 4.0 backspace will put more tire to the curb.
01-27-2017, 12:38 PM | #7 |
Actually the negative offset on the smaller backspace will put the outside edge pretty close to the other. I think they will be so close you won't notice a difference.
If both had zero offset then the 4 back space would move the outer lip out, but negative offset of 12mm (a bit smaller than .5) will pull the outer lip back in. Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
