01-26-2017, 10:25 PM | #1 |
Tubular A Arm info needed (bagged 64)
I'm working on a 64 C10 and have tubular a arms with mustang II ball joints. That setup has 5x4.75 rotors on it but I'm trying to switch over to bigger McGuaghys big brakes and spindles that are 6 lug. This bigger spindle raises my upper A arm 1/2-3/4 inch higher then the mustang II spindle. Also I'll have to ream out my lower ball joint mount and weld in a sleeve for a larger ball joint.
My upper A arm and lower are close to parallel but not quite. How big of a deal is this? Just want to make sure I can run the bigger stuff and not effect its ride or laying out or any other things I'm not thinking of. Any advice or personal experiences? |
01-27-2017, 08:09 AM | #2 |
Re: Tubular A Arm info needed (bagged 64)
You can go through and measure everything including the rack location and the position of the tierod ends and look to see where all the angles will be at ride height. This will give you a starting point to see if it all looks reasonable. The next step is a bunch of work but the only way I know to do it and this will tell you how well it will drive. The process we used to check the bump steer on the drag cars we built was to set the caster, camber and toe at ride height and then raise the front up an inch at a time and remeasure the toe and repeat this for through the travel and then do the same thing for a couple of inches down. Some times we would have to move the rack and or the tie rod ends to get it under control. Caster gain, and ackerman are also important and a good bit harder to check. There is also software out there from guys like performance trends that will do all of it based on good measurements that is not that expensive and could save lots of time and some money. To do all the checks your self you at least need a decent caster camber gauge.
Jimmy Software http://www.auto-ware.com/software/asgp/asgp.htm An online one that may help http://www.racingaspirations.com/app...ry-calculator/
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
01-27-2017, 12:57 PM | #3 | |
01-30-2017, 12:42 PM | #4 |
It is their setup, I'll check to see what they say as well. The smaller 5blug setup came with their kit so I assume it's good to go on their end since it shipped that way, I already had the big brake kit saved from a while Back and would rather run them if its possible. Thanks for all the info, once I get them on there I'm going to do some measurements as well
01-30-2017, 12:55 PM | #5 | |
