Old 10-14-2003, 10:06 PM   #1
Terry S
gas tank ??
I've put in a custom made fuel cell under the bed, and run a vent line to the fitting on the gas filler neck that I'm using. It has a vented gas cap, so I'm wondering if I need another vent line or if I'm set.
What do you all think?
TS
I can do all things thru Christ, but he evidently doesn't want me to beat that Camaro light to light....
Terry S is offline   Reply With Quote
Old 10-14-2003, 11:16 PM   #2
Orence1
Orence1's Avatar
Terry,
The original in cab tanks had a vented filler neck plus a vent tube that runs up the inside wall of the cab. The aftermarket Blazer poly tanks have two vents. I would think that another vent would be a good idea. Good luck.
Orence1 is offline   Reply With Quote
