01-27-2017, 03:51 AM | #1 |
Looking for efe valve 81 k10
I'm looking for a efe valve for my 1981 chevy k10 that has a 350, I might have to install this back on my truck and I'm having problems finding one. Thanks.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
01-27-2017, 10:09 AM | #2 |
Re: Looking for efe valve 81 k10
There's a lot on eBay. Might not be specifically for your application but I would think as long as it will bolt up, it should work.
01-31-2017, 02:29 AM | #3 |
bump any other suggestions? Would like to find a rebuilt or NOS part.
01-31-2017, 02:50 PM | #4 |
Which style did your truck have? The one with the actuator mounted at the valve or the one with the actuator raise up near the valve cover?
Low style: P/N: 5234815, searchable with results on ebay.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
01-31-2017, 05:33 PM | #5 |
http://www.ebay.com/itm/like/3319480...&ul_noapp=true
https://www.gmpartsgiant.com/parts/c...e~5234815.html I wonder what it would take to adapt an early model bi-metal spring-actuated heat riser valve?
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 01-31-2017 at 05:57 PM. |
02-01-2017, 09:24 PM | #6 | ||
02-02-2017, 06:41 AM | #7 |
You are looking for GM part 5233150.
You can try 1-800-243-0126 Nickson Industries, Inc. 336 Woodford Ave. Plainville, CT 06062 Tel: 860-747-1671 Fax: 860-747-1678 https://dl.dropboxusercontent.com/u/...20Catalog.html Or: Hamilton Manufacturing 822 Rennie Street Hamilton, ON (905) 545-4888 http://www.hamiltonmanufacturing.ca/hrv.htm#5233155 |
02-02-2017, 10:29 AM | #8 | |
02-02-2017, 12:50 PM | #9 |
Thank you very much guys for the info, I will look into the parts.
Thanks again! Got a question, I'm confused on how it will look once installed, am I going to need more parts because I think its supposed to look like this.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 Last edited by Matt Man; 02-02-2017 at 01:19 PM. |
02-02-2017, 02:21 PM | #10 | |
In Texas, it's 25 years and older.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
02-02-2017, 02:58 PM | #11 |
That's what I was trying to ask you, didn't realize you had never seen the one that was correct for the truck. The one you have pictured is the one I was trying to describe, with the actuator up by the valve cover. That is typically a van application. The two part numbers you've been given are the correct ones for your truck and they will require a small steel tube and some vacuum line to complete the connection. Another thing to consider is if you still have the vacuum switch to control the efe valve. It will screw into the thermostat housing and have a pair of vacuum lines connected to it.
02-03-2017, 03:27 AM | #12 | ||
05-15-2017, 01:06 AM | #13 |
Just a bump in this thread. I found a EFE valve today at the local pick n pull, the actuator holds vacuum just fine and the EFE valve itself is fine. It came out of a 82 c10 with the same emissions as mine. 10$ later it was mine.
Here it is painted up
05-15-2017, 10:26 PM | #14 |
I was going to say you might try pick n pull....cool you found what you needed...
