Active Member
![]() Join Date: Oct 2016
1972 c10 clutch pedal push rod question
I am looking for pictures of the stock location of the push rod. Mine was a factory 4sp but I don't understand where the rod penetrates the firewall. Also, what did you use for a master? Thanks for your time.
Pics please?? |
Re: 1972 c10 clutch pedal push rod question
oval shaped hole below the master and to the left...automatic cabs came with the hole and had a cover plate bolted over it....did someone weld yours up?
1970 short step c10 leaf spring 454 |
Active Member
Here's my firewall. Not sure what left you are talking about. Here's the current pic
Behind your header pipe. Looks welded.
1982 K10 SWB 1987 V20 - Sold - Doh! |
Active Member
Thanks. What have people done for aftermarket clutch master cylinder like a wilwood?
Active Member
Or this idea.
sub'd
72 GMC highlander nicknamed by my then 6-year-old brother "stripes" http://67-72chevytrucks.com/vboard/s....php?p=7378180 Check out my Youtube channel @Chad's Fab |
here is a picture of mine. Used to be a 6 cyl that is why my clutch rod is streight.
