01-27-2017, 03:51 PM | #1 |
Tail Light Mounting, Chrome conduit
I bought new tail lights and the chrome conduit for my 2nd gen 55. The connector on the back of the tail light housing comes straight out the back, and the chrome conduit simply will not bent enough to stay off of the fenders.
I'm sure pleny of others have had this problem, so surely there is a simple solution. I saw a couple routed through the fender, but I don't to drill the fenders for that. I tried using the boot from the wiring kit which is only about 45 degrees - helped a little but not near enough? Am I missing something here? I suppose I could raise the lights up in the stake pocket or space them forward. Any suggestions for a true 90 boot or other option? If I slip the chrome conduit directly over the connector, I have to bend it so sharply it breaks.
1955 SB Stepside 3100 big window cab on a 99 Ram 2500 Frame w/ 12-V Cummins diesel power and 47RH AOD transmission http://67-72chevytrucks.com/vboard/s...d.php?t=640042 |
01-27-2017, 04:31 PM | #2 |
Re: Tail Light Mounting, Chrome conduit
Just spitballing here (because I am going to have the same problem soon!)
How about looking for a chrome 90* elbow that will replace these boots in the plumbing department of your local big box store? I would think exposed faucet plumbing would need a 90* sometimes.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
01-27-2017, 06:57 PM | #3 |
I think most people route it horizontally and either go under the bed side or drill a hole and route it through the hole. Is that flexible metal cover specifically for that?
01-28-2017, 08:04 AM | #4 | |
Drill hole in bottom of light and route wires vertically, use plug in hole in rear of light? 90 degree boot made for flexible conduit? http://leinuoer.en.alibaba.com/produ...e_conduit.html |
01-28-2017, 12:53 PM | #5 |
Just a thought, do you have enough conduit to go over the top and come down to your light?? seems that there's more room topside??
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
01-28-2017, 01:30 PM | #6 |
I'd follow Dan's suggestion first and head to the local big box hardware or the local has everything plumbing store with the conduit and maybe even the taillight in hand.
This might let you sort out and figure out what you are hunting for https://www.plumbingsupply.com/chrome.html Half of hunting for something is knowing what you are asking for when you go hunting. you may be drilling and tapping and putting in set screws to make it work.
01-28-2017, 01:47 PM | #7 |
Post Whore
Could you swap the mounting brackets from left side to right?..that would flip them over and put the hole on the top side of the bracket and might give you a little more room..
01-28-2017, 02:51 PM | #8 |
On my truck I just put heat shrink tubing over the plugs and wiring tube that came with the tail lights. My mounting brackets are straight, so I look to have more room between tail lights and fender also.
'55 Chevy 1/2ton pickup w/ Pontiac 350 and Muncie M21 close ratio 4speed "Red Ryder" |
01-29-2017, 12:04 AM | #9 |
To use what you've got ,best option would be to mount them higher, another option would be to use some braided S.S. wire loom with some heat shrink on the ends.
http://www.ebay.com/itm/5-FEET-Braid...-/250907462515 I cant remember who it was , but one of the guys used a piece of SS tubing and bent it to use as conduit. It was Youngrodder post #6 here http://www.67-72chevytrucks.com/vboa...ht=tail+lights A 90* boot to look at to see if it would fit comes to mind ...A spark plug boot for a lawn mower might work ... Heat shrink would look good too. Might just want to run it to keep it tight to the bracket for a cleaner look.But nothing wrong with the way Capnduane ran his ,but if yours will be lower the wires will be less noticeable . Last edited by 1958Warrior; 01-29-2017 at 12:18 AM. |
01-29-2017, 07:56 PM | #10 |
I really like the polished SS solution that YoungRodder did. I should be able to find some scrap SS tubing at work. Thanks for the link!
01-29-2017, 11:13 PM | #11 | |
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
01-29-2017, 11:47 PM | #12 |
Some ideas I have taken pictures of at various shows:
Thought i had more, but i guess not. I saw one that was hardlined with polished stainless tube like this rubber one. Looked very clean.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! Last edited by Dan in Pasadena; 01-29-2017 at 11:56 PM. |
