Old 01-27-2017, 06:55 PM   #1
Richarde2194
65 c10 frame swap
Have a 65 Chevy c10 long box. I bought it already lifted and the owner was not sure wat king of frame it was sitting on, but the frame isn't in good shape..and the front axle is blown up. So I bought a 72 k30 to swap my 65 body over too...just want to kno if anyone has done this before and what kind of problems they have ran into
Richarde2194 is offline   Reply With Quote
Old 01-27-2017, 07:42 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 65 c10 frame swap
Frame horns will probably be your only real issue. The rear cab mounts also iirc.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-27-2017, 08:47 PM   #3
Richarde2194
Okay that's what I have found so far...just didn't kno if there was anything else I should be aware of before I start the project. Thanks for the help
Old 01-28-2017, 09:05 PM   #4
andyh1956
I'm using a '71 frame & rear mounts, front frame horns plus the radiator support mounts MAY be different, but I don't have a '66K frame to compare to, just a C frame. And the frame horns are a little shorter in height than the '71 frame. Come to think of it I think the whole frame is about a 1/2" different in height.
andyh1956 is offline   Reply With Quote
Old 01-28-2017, 09:39 PM   #5
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
It's highly discouraged for a 2wd because of the way it ends up sitting on the frame, but for a 4x4, I haven't heard anything in these forums good or bad.
66 C20 Service Truck:
