Old 01-27-2017, 08:13 PM   #1
67 Burb
67 Burb's Avatar
No-Rosion?
Does anyone use a product like No-Rosion in their cooling system, or does a 60-40 mix of Prestone and distilled water do the job well enough?
Bob
1967 2wd Burb, 350/TH350, 3.73 posi
67 Burb is offline   Reply With Quote
Old 01-27-2017, 08:34 PM   #2
BossHogg69
motor exploder
BossHogg69's Avatar
Re: No-Rosion?
I use Prestone brand antifreeze & distilled water 50/50 in my rides. No additives, and no issues - and it gets over 100* often during the summer here, but no where near as cold as what you deal with up there. One's a big block (AL heads), one's a small block (iron heads), and one is a 5.3 LM7 (AL heads). I do run an anode in the BB though.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 01-28-2017, 02:15 AM   #3
'63GENIII
'63GENIII's Avatar
Re: No-Rosion?
Prestone and distilled as well. Ive seen firsthand what our tap water can do to a new heater core. Makes me not want to drink it anymore. Distilled water is cheap insurance. An anode might be a good idea too.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 02-01-2017, 01:35 AM   #4
storm9c1
*** That's interesting ***
storm9c1's Avatar
Re: No-Rosion?
Agreed. Antifreeze + distilled water is all that's needed. Antifreeze contains corrosion inhibitors. 60/40 recommended in northern climates. No more, no less. A stronger antifreeze mixture hurts more than helps since the water is needed to carry away the heat more efficiently. Antifreeze alone cannot do that and works with water. But a 60/40 mix is better insurance. A frozen block is bad. A cracked block is a boat anchor.
That being said, No-Rosion is a decent product. It wasn't exactly developed for car radiator systems. But works there. I prefer to change and flush the cooling system every 3-5 years anyways, and that seems to keep cooling systems happy over the long term. The biggest enemy is neglect no matter what you use. The No-Rosion site also recommends this change interval even with their product. Once place it does excel is in systems that spend lots of time sitting (ie: museum vehicles, etc).
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
antifreeze, coolant, no-rosion
