Old 10-14-2003, 10:42 PM   #1
TIMSPEED
TIMSPEED's Avatar
HELP FAST PLEASE! How do I get a front fender off a C10 FAST?!?!
Where are the bolts and what size sockets do I need? A friend of mine just got a C10 in his shop, but he said if I wanted anything off of it, I have to get it before 2moro morning. The fenders are PERFECT, so I'm gonna yank em. I seen that there's 4 bolts on the radiator core support, and then 2 behind the door (only accessible when door is OPEN). Where are the rest?
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 10-14-2003, 10:46 PM   #2
Russell
Professional Grade
Russell's Avatar
On the 76 there was one on the door, one under the body attached to the cab, some along the inside of the fenders, and along the inside of the rad support.
Just keep pulling bolts till you get it. You'll be needing 1/2 and 9/16 sockets, and at least a couple hours to get them.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 10-14-2003, 10:47 PM   #3
Jonboy
Slots go on anything!
there is a 9/16 headed bolt on the backside of the fender, behind the wheel. there are also two 1/2 headed bolts that hold the valence panel to the fender in the front. Take a 1/2 and 9/16 sockets, an extension, and ratchet. That should get the fenders off. BTW, there are 2 9/16 bolts that hold the inner fenders to the cab, if you are taking them too. If not, there are 6 (I think) bolts in the wheel opening, and 4 at the front of the inner, all 1/2 head
1974 Jimmy- 5.3/4L80e/NP241
Old 10-14-2003, 10:50 PM   #4
Russell
Professional Grade
Russell's Avatar
Jonboy, the link under your name doesn't work
1/2, 9/16, and an extension with some patience will getcha new fenders =)
Old 10-14-2003, 10:51 PM   #5
TIMSPEED
TIMSPEED's Avatar
I got the sockets..but only got 10 minutes to pull of a fender...The truck is entirely stripped, only like the body panels left on it...
See Them Here
Old 10-14-2003, 10:51 PM   #6
stan79chevy
stan79chevy's Avatar
penetrating oil
dont forget to grab some wd 40 or something it will help save some time
79 chevy k20 350/350/205/D44/14bFF
4.56 gears rock
LWB pimer black
01 S-10 ZR2 extended cab
4.3/4L60E/233
3.73 gear 31" DICK CEPEK CRUSHERS
stan79chevy is offline   Reply With Quote
Old 10-14-2003, 10:54 PM   #7
Russell
Professional Grade
Russell's Avatar
you can do it in 10 minutes if you really want it
Old 10-14-2003, 10:56 PM   #8
TIMSPEED
TIMSPEED's Avatar
Good!
See Them Here
Old 10-14-2003, 10:57 PM   #9
Russell
Professional Grade
Russell's Avatar
Why are you still here?! GO GO GO
Old 10-14-2003, 11:01 PM   #10
TIMSPEED
TIMSPEED's Avatar
Gotta wait till 2am...
See Them Here
Old 10-14-2003, 11:23 PM   #11
gldevall
gldevall's Avatar
Sounds like they are free for the wrong reason.
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 10-14-2003, 11:24 PM   #12
low 84
low 84's Avatar
this sounds legal.....not go steal those fenders
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 10-14-2003, 11:31 PM   #13
TIMSPEED
TIMSPEED's Avatar
Naw, they're free for the RIGHT reasons, trust me
See Them Here
Old 10-14-2003, 11:32 PM   #14
TIMSPEED
TIMSPEED's Avatar
Actually, it IS legal..what's NOT legal is the truck was sitting in front of my friends shop (out in the country) for 3 months! Someone left it there completely stripped, so he assumed ownership of it.
See Them Here
Old 10-14-2003, 11:59 PM   #15
low 84
low 84's Avatar
sounds like the 83 cutlass we turned into a convertable (sawzall) and then left on the side of the road after we broke it off roading. i was actualy figureing that the truck had been wrecked and he was letting you grab the fenders before the insurance company got the truck, lol.
'05 1500 Crew Cab
RIP
Old 10-15-2003, 12:38 AM   #16
TIMSPEED
TIMSPEED's Avatar
Actually, someone is coming 2moro morning to pick up the frame/suspension (perfect condition ½ ton rolling chassis) and he said I could have whatever I wanted off of it.
See Them Here
Old 10-15-2003, 12:52 AM   #17
crossy
Oh,you can't buy that new
crossy's Avatar
tim, take some extensions and a swivel if you have it . a few of the ones on the front behind the headlight bezel can be a hassle w/o the right tools. there are 2 way up high behind that bezel.. A 15mm torx head (T-15) will be needed to get the headlight bezels off. Sometime the bezels are held on the top with 9/32 headed screws but mostly with more t-15 screws. there is a bolt down low in the front behind the bumper tht attaches the grille filler to the fender and a bunch down near the charcoal canister. open the door and get one of the upper, rear ones with a 9/16 and the extension. another 9/16 on bottom inside the fender and one from the top near hood hinge. (3) 9/16 and the rest should be 1/2". DAVE
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 10-15-2003, 07:24 AM   #18
TIMSPEED
TIMSPEED's Avatar
OK, well, I got a new set of doors and fenders! I went over there sight-unseen and BOY what a surprise! The doors and fenders are PERFECT CONDITION! NO RUST AT ALL! NO HOLES AT ALL! Only like three small dents on the drivers side door and fender. This all came off a 79 SWB Stepside. I woulda took more, but mostly everything was GONE.
So, my search for doors and fenders is OVER.
The only thing that I don't like..is the doors are cut for a 6x9 speaker at the bottom...I wanted to run 6x9's anyway..but I wanted to cut the holes myself...
See Them Here
Old 10-15-2003, 07:57 AM   #19
houston6
houston6's Avatar
Congrats on the doors and fenders why cant i ever get that lucky lol
Scott
houston6 is offline   Reply With Quote
Old 10-15-2003, 08:16 AM   #20
TIMSPEED
TIMSPEED's Avatar
Originally posted by houston6
Congrats on the doors and fenders why cant i ever get that lucky.
Just wait my friend, I'm sure you'll get lucky in some way or another
See Them Here
Old 10-15-2003, 09:22 AM   #21
Low87
been here longer than Liz
Low87's Avatar
That's awesome man! Nice to hear of a good find like that.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 10-15-2003, 09:30 AM   #22
crossy
crossy's Avatar
As Cartman would say "YOU BASTARD" .
free, rust free doors & fenders great score !
If you put a piece of sheet metal over the holes and install the factory type carpet bootoms on the doors you can start over and put the speakers wher you want. the carpet bottoms are available aftermarket so you don't have to hunt for good used thatare the right color. They are a fairly easy piece to dye to dark color though. DAVE
98 Vortec project.
94,3500,6.5L 4L80
Old 10-15-2003, 09:35 AM   #23
Izzy
Trucker.
Izzy's Avatar
Yeah I need 2 doors too.
Izzy is offline   Reply With Quote
Old 10-15-2003, 09:21 PM   #24
78SilveradoSWB
78SilveradoSWB's Avatar
Here are couple on Ebay, not exactly for free, but they look good.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33642
Too bad they are in So. Dakota, wrong time of the year to drive there.
Mitch
1978 Chevrolet Silverado C 10
454 BB, TH400
78SilveradoSWB is offline   Reply With Quote
Old 10-15-2003, 09:32 PM   #25
Russell
Professional Grade
Russell's Avatar
This thread is useless without pictures
