Old 01-28-2017, 10:53 AM   #1
Andy4639
Old member
Andy4639's Avatar
90's seat install
I installed a 90's model bench seat in the old Ramp Rat truck yesterday and just wanted to share some info with everyone who may be thinking about this mod.
The seat fits almost perfect in the truck with just a little bit of modifing. I really like they way they sit too!
First you need to set the seat in the truck and then loosen the 4-5/8" head bolts in the front frame of the seat. This will let the seat frame match the holes in the truck floor board. Put the bolts in and tighten them to mark the rear frame holes. This insures the seat is good and straight when mounted.
I also used 2 big nuts on each back hole to raise the seat up and make it sit better. For me anyways.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-28-2017, 11:50 AM   #2
RPBurris
RPBurris's Avatar
Re: 90's seat install
I have the same model seats installed by the PO. There was a block of wood on the left side of the passenger side seat to level them out. Did you have to block this up somehow? They are great seats though!
1969 Chevy K20 Longbed
RPBurris is offline   Reply With Quote
Old 01-28-2017, 02:46 PM   #3
kaycee
kaycee's Avatar
"I also used 2 big nuts on each back hole to raise the seat up and make it sit better. For me anyways"
Right there in the last sentence
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 01-28-2017, 03:49 PM   #4
Andy4639
Old member
Andy4639's Avatar
Talking Re: 90's seat install
Yes!
Old 01-28-2017, 05:18 PM   #5
TwoFiftyShifter
I did the same seat, but instead used the existing rear holes and drilled holes for the front. I think I will sit a tad lower than you doing it this way.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 01-28-2017, 05:47 PM   #6
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 90's seat install
Yes it should sit lower but do you have any adjust ment? Mine has some but not much to the back but has pretty good adjustment forward which is good since I have been teaching my daughter how to drive a straight drive with it.
Old 01-28-2017, 06:49 PM   #7
TwoFiftyShifter
Almost no adjustment. I like where it is and if my wife gets a wild hair to drive it one day, her legs are as long as mine.
1982 K10 SWB
Old 01-28-2017, 07:01 PM   #8
1968aj
have you ever checked into having one of these seats recovered? just wondering if it would have to just be recovered over existing upholstery or if the old can be removed. I have one that I want do with houndstooth inserts.
1968aj is offline   Reply With Quote
Old 01-28-2017, 09:46 PM   #9
custom10nut
custom10nut's Avatar
That looks great. Perfect color too. Back it the late 90 s I looked and looked for that very style seat, for like three years, with no luck. I ended up finding a pair of blazer buckets for a steal, and went with them instead. I still look for a seat like this, to put in a truck I don't have yet. You can never be too prepared.
The Ramp Rat is coming along nicely.
custom10nut is offline   Reply With Quote
Old 01-29-2017, 02:30 AM   #10
ratty69
Looks great! I really like those early 90's seats.
I'm in the process of putting one in my truck. I didn't want to drill any holes in my floor so I tossed the 90's base and made up some adapter plates to bolt the bench to a set of 72 tracks using the original holes.
ratty69 is offline   Reply With Quote
Old 01-29-2017, 10:55 AM   #11
Andy4639
Old member
Andy4639's Avatar
Thank you sir.
It's coming along nicly.
1968aj
Yesterday 05:49 PM
No I have not. The one in my 71 years ago wore well with very little wear. This one isn't as nice of seat but I do plan to look into having it recovered.
Old 01-29-2017, 11:44 AM   #12
raggedjim
raggedjim's Avatar
Check this thread, I had mine recovered as well as a couple other guys.
http://67-72chevytrucks.com/vboard/s...=511232&page=2
Good, luck, Rg
raggedjim is offline   Reply With Quote
Old 01-29-2017, 12:34 PM   #13
my56chevytruck
my56chevytruck's Avatar
wow, I like those seats. already have mine, but sure would have liked to have run across those when I was looking.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
