Old 01-28-2017, 01:37 PM   #1
Tonyc10
Tony's 64 c10 fleet side build
Hello everyone,I wanted to introduce myself. My names is Tony and I've been reading and watching other guys truck builds for some time now. Seeing others truck builds has really inspired/motivated me. Ive always loved modifying my vehicles and spent alot of time working on one of my buddies old c10 years ago. The truck I'm building is something I would like to hold onto long term. My son jack (2.5 years old) has been out helping me and also loves a good project. My goal is to have a nice well rounded truck that I can drive on the street and take to the strip every now and then. Im trying to keep up the momentum on this build as I would like to see it come together by the summer time. I purchases my truck in Washington and after a lengthy amount of paper work brought it an hour north to it's new home in
mission, bc, Canada. I got the truck at the end of September 2016.
Tonyc10 is offline   Reply With Quote
Old 01-28-2017, 01:45 PM   #2
Tonyc10
Re: Tony's 64 c10 fleet side build
Here is a pic of me dragging my 64 home
Old 01-28-2017, 02:01 PM   #3
Tonyc10
Some pictures of the truck the day I got it
Old 01-28-2017, 02:09 PM   #4
Tonyc10
For me to register it in my name the truck had to be inspected. It had a 327 motor in it but the previous owner had taken it some what apart. For it to pass inspection It needed to run and drive. Myself, buddy and my cousin worked on it for three evenings. It wanted to run but we couldn't get it to to idle properly. We were very confused. It was getting gas and spark and had compression. We were playing with the distributor adjustment and timing gun,just couldn't get it right. Well we thought maybe the cam was worn out. I located a good cam and upon installing it found that the previous owner reassembled the cam and crank alignment wrong. The cam timing was off.
Old 01-28-2017, 02:14 PM   #5
Tonyc10
We replaced the cam and lifters just because and corrected the cam timing and put it back together. Vroom. Fired right up. Alot of work to make something run That your just gonna take apart again, but gotta do what ya gotta do.
A snap shot of me and my little man getting it ready for the trip to the inspection shop.
Old 01-28-2017, 02:23 PM   #6
Tonyc10
I sourced a early model sbc 350 motor and sent it to be cleaned and magna fluxed. Unfortunately it was found to have some cracks in it near a coolant passage. Luckily the old guy who u bought it from (an ex hot rod shop owner) was nice enuf to help me locate a replacement from a buddy of his. Along with the new block the buddy of his had some vortec aluminum heads and edelbrock intake Mani for sale. I had this block cleaned and magna fluxed and it was good. Sent it out to the machine shop and bored it 30 over and all new internals.. Here's a pic of the finished block after I prepped and painted it.
Old 01-28-2017, 02:25 PM   #7
61K10
61K10's Avatar
Welcome--tk looks good, and now have fun.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 01-28-2017, 02:28 PM   #8
Tonyc10
I ordered the 4" grand slam kit from cpp and ordered replacement tin for some of the beaten up pannels. Got the truck back from inspection, and now I can finally begin the tear down.
Old 01-28-2017, 02:33 PM   #9
Tonyc10
Hey thanks, I have a couple more posts to update to where it is currently.
Here is the bed fully striped
Old 01-28-2017, 02:36 PM   #10
Tonyc10
I removed the trailing arms, rear axle and cross members. Melted the bushings out of the trailing arms
Old 01-28-2017, 02:41 PM   #11
Tonyc10
With the help again from my buddy Matt and my cousin Thomas we took the motor and trans out and separated the frame and cab. Removed the windows and interior and took off the front cross member/suspension.
Old 01-28-2017, 02:53 PM   #12
Tonyc10
With the frame free I was able to take it to my cousins work place on the weekend, we wanted to convert the truck from a long bed to a short bed. He made a jig and we loaded it on his roof rack and took it to the shop. We plasma cut the frame under the cab location taking out a 12" s shaped section. We then rewelding it after tacking it and measuring it a bunch.
Old 01-28-2017, 02:57 PM   #13
Tonyc10
There is something semi terrifying about a frame in two pieces. We also relocated the rear cab mounts and removed one of the cross member brackets. We now had a short bed frame
Old 01-28-2017, 03:11 PM   #14
Tonyc10
Up next was to sand blast the frame. Once I had dropped it off at the blaster I went to a local wrecker and found a bench seat to replace my super bouncy stock one. I got a bench out of a mid 90's Chevy 1500 reg cab. It was a real deal for only $60 bucks. After going to multiple upholstery shops I found a local guy who gave me a good deal. Here are some pics of the seat before and after. We filled in the head rest and added foam for areas that needed it.
Old 01-28-2017, 03:13 PM   #15
Tonyc10
Decided to go with a turbo 350 transmission. Had it rebuilt, with a shift kit and new tourqe converter.
Old 01-28-2017, 11:30 PM   #16
Tonyc10
Started to tackle some of the floor rust today on the truck
Old 01-31-2017, 11:35 AM   #17
Tonyc10
Got some more work done last night. Began welding in some floor patches and removes the dash
