Old 01-28-2017, 06:34 PM   #1
jwn1975
Will these fit!
I am considering buying a set of rocket racing wheels. I have disks up front on my 1970. Will these work?
jwn1975 is offline   Reply With Quote
Old 01-28-2017, 06:37 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Will these fit!
I have 15" ET slots up front on my 1972 GMC C15 (stock front discs) and I had to do a tad bit of grinding on the brake calipers to get them to clear.
If you are running disc brakes up front that are any larger than a stock type setup, then a 15" wheel probably won't fit.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
