![]() Join Date: Jul 2013
A couple questions...SOOO CLOSE!
Well the weather has finally been bearable enough to be out working on the truck. I am down to a couple last thing before i try to fire her up. So the 350 and th350 were pulled from a 78 camaro, the charcoal canister was in the camaro but not hooked up and im wanting to since gas tank is now in the bed and the cap i ordered isnt vented (dont think). The canister has 2 small ports for vacuum, 1 labeled carb bowl but i see nowhere on carbs to hook up, 1 for pcv which is obvious and 1 to the gas tank. Any help is much appreciated...oh and on the carb i do have a vacuum line that used to go to power brake booster which is no longer used so instead of plugging it can i use this for the vacuum to the canister?
#2 | ||
"I ain't nobody, dork."
Re: A couple questions...SOOO CLOSE!
I'd ditch the smog canister all together and just vent the rear tank at the tank.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
So plug the vac line that used to be for brake booster and a short piece of tube from vent line on tank and secure to frame and call it good? Need a breather filter on the end or anything?
