Old 01-28-2017, 10:17 PM   #1
Ramiro0727
Starter wiring
Just finished wiring up my sons truck with a new wiring harness from American Autowire Power Plus 13. I wanted to test out the headlights and the signal lights. But when go and hookup the battery cables. The starter spins. I don't think I connected the starter correctly. The starter didn't come with any instructions. Can someone take a look at the pic and tell if I connected it correctly.
Thanks,
Ramiro
Ramiro0727 is offline   Reply With Quote
Old 01-28-2017, 11:47 PM   #2
Steelheader
Steelheader's Avatar
Re: Starter wiring
From what i can tell the heavy gauge wire that is black in photo should be moved over to the other larger post , nothing should be attached to that threaded post except the existing copper jumper wire that feeds the starter motor , so by you having that hooked up on that side as soon as you hook battery up you are bypassing solenoid and causing starter engaging .
Hopefully that helps
Steelheader is offline   Reply With Quote
Old 01-28-2017, 11:53 PM   #3
Steelheader
Re: Starter wiring
Here's a generic photo that might help
Old 01-29-2017, 12:16 AM   #4
Steelheader
Re: Starter wiring
Here's a better diagram to help you with the smaller wires , the purple should be the neutral safety switch wire and the red one should go to coil
Old 01-29-2017, 12:28 AM   #5
Ramiro0727
Re: Starter wiring
Thanks Steelheader. That's what I thought I did. Just hope my neutral safety wire is hooked up to the correct terminal. Also I didn't connect any other wire since I don't have a coil.
Ramiro
Old 01-29-2017, 03:15 AM   #6
88Stanger
88Stanger's Avatar
Re: Starter wiring
call me crazy, but it looks like the main lug nearest the starter should only have the main lead from the actual starter to it, but there appears to be a large black main lugged lead going to it. Is that by chance your main lead from the battery? if so, that is why the starter goes on as soon as you connect to the battery. This main lead must go to the main lug that is opposite of this one, or furthest away from the starter, as shown in the earlier pic.
88Stanger is offline   Reply With Quote
Old 01-29-2017, 04:30 AM   #7
Ramiro0727
Re: Starter wiring
88Stanger I hooked up the main battery to the wrong lug. Hopefully I hooked up the correct lug for the neutral safety switch. I will change the battery cable tomorrow. Hopefully tomorrow we can get my sons truck going.
Old 01-29-2017, 10:38 AM   #8
scooterpimp
scooterpimp's Avatar
Re: Starter wiring
Battery cable needs to move up to stud on solenoid..
scooterpimp is offline   Reply With Quote
Old 01-29-2017, 10:52 AM   #9
geezer#99
geezer#99's Avatar
Re: Starter wiring
Ramiro
It's not. The purple wire goes to the other small terminal.
geezer#99 is online now   Reply With Quote
Old 01-29-2017, 06:09 PM   #10
Ramiro0727
Re: Starter wiring
geezer#99 so my purple wire is hooked up to the wrong terminal? Looks like I need to get under the truck again. I switched the battery cable. All my lights work except my reverse tail lights. So I will switch the wire. Thanks for you help. Hopefully that will take care of my reverse tail lights.
Old 01-29-2017, 06:10 PM   #11
Ramiro0727
Re: Starter wiring
Thank you all for the replies. It has helped me a lot.
