![]() Join Date: Jul 2016
A/C system, complete big block or small block
I have decided to part with one set. You will get everything for a full conversion to include complete uncut dash and firewall cut for pattern.
Dash, $100 Firewall cut $60 Brackets, small block. $125, big block, $250. All inner and outer ducts, vents, lines, bolts nuts etc. condensor and evaporator. Cowl vent with all screws and return spring. Passenger side vent with screws, vacuum actuator and spring. Wiring harness cables and heater- A/C controls. $500 for all that stuff. I have removed dozens of these systems and installed them in non-A/C trucks and know all the parts it takes to complete an install and you will get everything. I priced the dash and firewall cut Seperate because the conversion can be done without these parts. I estimate shipping at $75 without the dash and $150 with it. I have 2 of the outer a/c boxes still installed so I don't know the condition yet on those, I assume they will need some restoration of the metal plate as most have some rust. I will post pics upon request of specific parts |
| Bookmarks |
