V8 Radiator Shrouds: Differences - Dimensions
For small block V8 trucks I notice there are more than a couple factory shrouds. What are the depths and applications? For reference I have a '71 GMC with a factory 350, 4 speed and no AC. The engine is forward of automatic trucks I've had in the past (??). Looking for a shroud deeper than this. Does it exist?
Thanks, Steve weim55 Colorado |
laying low
![]() Join Date: Mar 2001
Re: V8 Radiator Shrouds: Differences - Dimensions
The page straight out of the LMC catalog.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
the factory 2wd a/c shroud is about 5" deep, the 2wd non a/c shroud is about 6" deep, the 4x4 shroud is about 9"deep. I say "about" because the shrouds are tapered - they measure deeper at the top, more shallow at the bottom. The 4x4 engine is set back compared to the 2wd.
I have a feeling something isn't being shown here. Going by memory, a rusty memory: The '71 I had years ago was a factory virgin everything 350 - 350 Turbohydro no AC C10 2WD, the distributor was right next to the firewall, an HEI wouldn't even fit it was so close. My current '71 350 4 speed no AC C10 2WD is good 4 to 6 inches from the firewall. Wondering if someone might have a measurement of the shroud depth of an automatic truck like my first '71?
I need as deep of a shroud as I can get. Steve weim55 Colorado |
Roadtrip!
![]() Join Date: Feb 2003
weim, I think your first truck sounds like the 6 cyl position was used. A factory v-8 uses the forward most holes unless a 4x4 I believe.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Any reason a 4WD shroud wouldn't work on a 2WD truck?
Old member
I wished I seen this earlier. I just installed a NOS shroud in my Ramp Rat truck Saturday morning. I could have gotten the measurements for you.
350/4 speed no AC. The only difference I have ever seen where for the 4x4 trucks and 2 wheel drive. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
It will work IF the sbc engine is mounted in the 6 cyl. or rear motor mount perches. I had a sbc mounted where the 6 cyl. I took out, used a 4 wd shroud and it worked fine.
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
thanks for the info guys!
