Need to ID the correct handle for factory overdrive in a '67
Could anyone supply me a pic of the under dash control handle on a truck with a factory overdrive??
Thanks, Steve weim55 Colorado |
Old member
I don't have any pictures of my old transmission with over drive but it was a handle like the E brake but had overdrive written on it. I think it was chrome also instead of the black plastic.
If I knew now what I didn't know back then about these trucks I'd have a bunch of old stuff.I gave away the transmission and frame for $100.00! ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
BlahBlahBlah
Re: Need to ID the correct handle for factory overdrive in a '67
You are correct it was chrome on the 67's. Ive had a 67 and a 69, 67 chrome and 69 black plastic.
Found a pic of the 69 not the 67, sorry. |
I have a chrome handle out of a '63 car. Hoping the cable will be long enough for the truck. Surprised the overdrive 3 speed was available all the way to '69 !? Thanks for the info!
BlahBlahBlah
Im still looking for the 67 pic. I had it quite awhile back, but if I find it ill post it.
That would be much appreciated!
Is this the 67 style? Here Iso the page I got the info from. http://67-72chevytrucks.com/vboard/s...d.php?t=673675
Fixed the link above
BlahBlahBlah
Found the pic of the one in my 67 ....
#10 | |
Old member
![]() Quote:
At least it looks like my old one did. ![]()
Roadtrip!
![]() Join Date: Feb 2003
This is in my 67 and listed on the SPID sheet.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
I need to install my cable in my 67 C10. Can anyone please post a photo of the where the cable exits the cab and where it passes the shift linkage?
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod |
