Old 01-30-2017, 10:28 AM   #1
PowerdbyChevy79
PowerdbyChevy79's Avatar
8 lug to 5 lug conversion
Whats up brothers..hoping yall can help me.. I have 82 swb..it has a 10 bolt diff.. and I came upon a 14 bolt out of a 83 3/4 ton.. I was wondering if I could I could convert it to a 5 lug.. and I'm will it bolt in to the original location or will I have to modify it.. any info is much appreciated.
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1976 C35 Sierra Grande "Mr. Harvey"
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
1982 C10 Silverado "Lucy"
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 01-30-2017, 10:48 AM   #2
Mattchu60
Re: 8 lug to 5 lug conversion
You can bolt it into place of the 10 bolt - I did it on my truck. You need a "trick" u-joint to get the driveshaft to bolt up to the 14 bolt yoke. The spring perches line right up. The parking brake cables are different - I bought new set from the 14 bolt to the main cable that comes from the cab, at that point they are the same (on mine).
What I cannot tell you is if they make 5 bolt axles for it - the first thing to know is if you have the full floater or the semi-floating axle.
Mattchu60 is offline   Reply With Quote
Old 01-30-2017, 11:32 AM   #3
Hewfil1
Hewfil1's Avatar
Following this, recently got myself a full-float 14 bolt.
Hewfil1 is offline   Reply With Quote
Old 01-30-2017, 01:04 PM   #4
PowerdbyChevy79
is the 14 bolt track width wider?
1966 C10 "Mary"
Old 01-30-2017, 01:13 PM   #5
PowerdbyChevy79
I'm not sure ..its coming out of a 1983 3/4 ton not sure what floater it is..how would I tell the difference?
1966 C10 "Mary"
Old 01-30-2017, 01:22 PM   #6
Mattchu60
The full floating axle will have large hubs on the axles where the wheels mount, where the semi-float will not - it will look like the 10 bolt (but larger with 8 lugs).
Out of an 83' truck the tracking width should be the same, I believe they got wider when they went to the next gen trucks in 88'.
You'll probably be looking to spend some serious $$ if is you want to convert over to 5 lug for custom parts. I left mine as an 8 lug, fyi.
