01-30-2017, 09:54 PM | #1 |
Front drivers side wheel clicking with speed
Hello,
I'm getting clicking above 5-10 mph that sounds like playing cards in a bicycle spoke. It's relative to my speed and sounds as if it's coming directly from my drivers side front hub (K10). No play in the wheel. When coming to a stop I also get a sudden "clunk", then quiet until I hit 5-10 mph, then click click click. Does this sound like an accurate symptom of a failing auto hub or wheel bearing? |
01-30-2017, 10:31 PM | #2 |
Post Whore
Re: Front drivers side wheel clicking with speed
I had a set of those auto locker hubs once that my uncle gave me..they started that clicking noise..then they disintegrated...there was a plastic dololly in there that wadded up..went back to manual hubs and never looked back
01-30-2017, 10:39 PM | #3 |
Okay just making sure that's the deal.
Another question, is the hub/rotor all one piece? Rockauto shows multiple rotors that "fit", but only one that is an all in one hub/rotor. Do I need to get the all in one or will does the hub come off the rotor and go back on a new, cheaper rotor? |
01-31-2017, 07:58 AM | #4 |
Sounds like a front axle ujoint
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
01-31-2017, 08:56 AM | #5 |
Post Whore
I'd jackup that corner and pull the wheel off so you can look at everything..you may get your answer quickly by just rotating the hub with no load on it..check your rotor while your there to see what you need
01-31-2017, 09:22 AM | #6 |
Do you happen to have a dust shield on the backside that may have gotten whacked and bent out of shape? Thought this might be the cause till I reread your post about the "clunk".
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
01-31-2017, 01:15 PM | #7 |
My first thought was the the universal, but could be in the hub as well. It is easy enough to turn the wheels and inspect the universal.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
02-01-2017, 12:03 AM | #8 |
I pulled the wheel. What exactly am I looking for? I don't hear any clicking when I spin the rotor. I know my rotors are warped so I'll be replacing them anyways.
Does the hub portion separate from the rotor? Since I'll be pulling it all apart anyways to do the brakes, I'll swap over to warn manual hubs, new wheel bearings and new axle u joints. Anything else while I'm in there? |
02-01-2017, 12:14 AM | #9 |
Post Whore
What year truck are you working on?
02-01-2017, 12:25 AM | #10 |
Post Whore
I know the mid 80s rotor where held to the hub with the lug bolts..knock the lugs out and the rotor comes loose
02-01-2017, 12:26 AM | #11 |
85 k10 5.7 Scottsdale
02-01-2017, 12:29 AM | #12 |
Post Whore
Replace axle seals as well..
02-01-2017, 12:31 AM | #13 |
Got it.
02-10-2017, 06:55 PM | #14 |
Trying to confirm what parts I need.
Inner wheel bearing and race. Outer wheel bearing and race. Axle seals Axle u-joints Upper and lower ball joints Spindle bearing Grease Rotors/pads Manual locking hubs Anything else to get before I tear everything apart? |
02-11-2017, 12:24 AM | #15 |
hub seals
02-20-2017, 10:04 PM | #16 |
I have a question. I am putting my axle back into the axle housing. I am holding up an axle seal to the axle where I think it should go. Except for it keeps the axle from going into the housing all the way. Is there supposed to be a seal of some sort on this part of the axle?
02-21-2017, 03:06 AM | #17 |
buy a Haynes repair manual, they are great and have good illustrations..
02-21-2017, 11:20 AM | #18 |
02-21-2017, 05:03 PM | #19 |
02-28-2017, 12:31 PM | #20 |
All fixed up, thanks guys. No more clicking.
