Can anyone ID this diff?
Im trying to see if this will work in my 61, but the owner isn't sure what it is...
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE |
![]() Join Date: Sep 2006
Re: Can anyone ID this diff?
How many bolts in the cover and how many lugs dose it have? Looks like something that came out of 60 to 72 chevy truck depending on the Lugs. The pumpkin looks kind of small in that picture, but it could just be the angle.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
Thats what I was thinking too. He is getting a measurement of how wide it is... i will ask about how many bolts on the cover.
Moderator
![]() Join Date: Dec 2012
I have an idea... but just get him to turn it and take a pic of the back. We'll know immediately.
![]() Join Date: Jan 2011
Looks like one out of a 4wd. Almost looks like it has the bigger brakes on it.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Here are some more pics. I have a feeling this is way newer than what Im looking for...
![]() ![]() ![]() ![]() Also, I found another rear end thats out of a 66 GMC Suburban. The guy that has it says its not a 12 bolt though. What other options did the GMC Suburban have?
That's definitely a 12 bolt
I think it may be from an 80s truck, which would make it too wide for my 61...
Still wondering what the 66 GMC Suburban would have if its not a 12 bolt....
gmc dana 44
1961 chevy K10 my build is------------61K10 build |
Moderator
![]() ![]() Join Date: Aug 2011
That's your basic 12-2 Alpha Delta Charlie right there. Basically.
What does 12-2 ADC mean?
#13 |
Moderator
The phrase is "your basic 12-2 Alpha Delta Charlie".
Whatever I want it to mean. In this case, I'm clueless as to what the rear end is. ![]()
#14 |
LOL awesome. Ill have to remember that one...
#15 |
Does the 61 also have leaf springs? Spacing? What about U joint match up?
I have a 1970 (or 71?) 12 bolt in my 66 and like it that it is 1 1/2" wider than original. |
#16 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
That differential IS a truck 12 bolt. It will be 1.5" wider than your original Eaton HO32/33. If it is 6 lug it will have been out of a 4x4.
A GMC will likely have a Dana 44 as already stated. Personally I would stay away from the Dana 44 as the brake drums are basically nonexistant and you have to modify other drums to make them work.
#17 |
Thanks for the replies!!!
I found a local diff shop that will rebuild my stock rear and put 3.90 gears in it for $500. I am debating going this way. A newer 12 bolt would be nice, but between the price of the rear end and the work moving mounts and pan hard, maybe the $500 isn't too bad...
#18 |
3.90 gears haven't been made for years. A set of nos ones on e-bay are $495 just for the ring and pinion. Have them put in 3.38"s as they are ave.
#19 |
he has 3 sets of 3.90 gears at the shop. He is throwing a set in for free basically with the rebuild. If I want 3.38, then I have to buy a set.
I have a 700r trans, so 3.90 should be fine... Do you guys think I should just rebuild what I have for $500 and not worry about looking for a rear end?
#20 |
Moderator
Keep your stock rear housing and have it built.
#21 |
The biggest downside of the stock rear end is not being able to get a Posi for it. But I guess don't really need one...
#22 |
I don't know about the earlier stuff but if you already have a 12 bolt, couldn't you swap the axle shafts out from a 65 or 66 to run a posi?
Is it more than a coarse vs fine spline difference on the 61 diffs? |
#23 |
60-62 were Eaton rear ends. Not 12 bolts. I wish it was that easy....
#24 |
10-4, that makes sense.
#25 |
Go for it at that price. I looked for a set of 3.90 gears with no luck when i did mine. With your trans you should be fine with the 3.90's. these gears new nos?
