alternator warning light help request
My 66 c10 has a recent crate 350 with a march pulley system and alternator.
my wiring under dash is a mess, with China fuse box and only the main wiring to drive the truck is correct. The warning light wires and sockets are not there at all. i want to run direct wires and sockets etc from alt. to dash warning light. but am confused of the correct wiring route and hook up. i have all the diagrams and books on the truck , but my lack of tech skill and knowledge make me very nervous on doing this. would appreciate a simple layman list of instructions of what to wire point to point. thanks Allan |
Re: alternator warning light help request
What alternator you running? plug in rear oem with external reg.? OR plug in side (at rear) built in reg.? OR one wire?
Sounds like a ONE WIRE alternator you CAN NOT run charge light with one wire
Add on VOLT meter would be your best set
Check if your alternator also has a 2 prong connector. Some newer alternators are convertible to allow for either the one wire connection or 3 wire (like mine). If so you can add the wiring to make it a 3 wire set up.
1966 C10 Short Fleetside 1988 Sportster, 2008 Street Glide Ken's 1966 C10 build "Red Ale" Follow on Instgram: @cv_performance https://instagram.com/cv_performance Harley Performance Parts: CV Performance (Harley related) Enjoying the ride! |
thanks all , i am going with gauge set voltmeter, found some nice small size by auto gage
