01-31-2017, 09:44 PM | #1 |
wheel spacer
i have a 63 C10 with drums in the rear and disc in the front, I just picked up some 22x9 transit wheels they have a six inch back space, will i need to purchase any spacer? I also would like to know what tire size I should get I don't want the tires to take up to much wheel well space cause I want to eventually install a airbag suspension to drop it, I was told that I should at least get a 7 inch drop from one without c notch or drop spindles. I think I can always add them later if I feel I want more drop but I'm not looking to cut any wheel wells, I guess I will have to see where I am with clearance once I install the bags to see if I can go any lower but I think that the right tire size selection and wheel spacers if needed is important and Im not sure what would be best for my situation. Any help would be greatly appreciated This is how she sits now with 15 inch wheels.
Thanks |
01-31-2017, 10:20 PM | #2 |
Re: wheel spacer
check out my build thread i just installed some 22" transit wheels. i had to run spacers in the rear.
well looks like you have already checked it out before |
02-03-2017, 04:08 AM | #3 | |
Re: wheel spacer
Sam |
02-03-2017, 07:38 AM | #4 |
Re: wheel spacer
02-03-2017, 03:23 PM | #5 |
Re: wheel spacer
I just threw some Victory wheels on my '61 that had about 6.5" of back spacing. They are temporary until i can get the wheels i want, so i used spacers to center the 245s in the rear fender well. I ended up going with a 1.5" spacer after trying 2" and 1.25"
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1 https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
1961 Chevy Apache "BoomStick" -First build, lots of plans, little experience. What's the worst that could happen? http://67-72chevytrucks.com/vboard/s...d.php?t=694506 |
02-05-2017, 06:36 PM | #6 | |
Re: wheel spacer
the ones on the spacers are metric. |
02-07-2017, 04:18 PM | #7 |
Re: wheel spacer
I used the lug nuts from the truck to bolt the spacer to the hub, then the nuts that came with the spacer to bolt the wheel on. Since these are temporary i wasn't too concerned about finding matching lugs
02-07-2017, 07:34 PM | #8 |
Re: wheel spacer
I don't think you can find matching lugs, At least I didn't.
