Repair turn signal housing studs in my grill
So I needed to paint my otherwise perfect grill on my 88 CC. Last light as I was taking it apart I ran in to a big problem. All the studs that hold the signal housings were brittle and snapping off instead of releasing the speed nuts. After thinking through several ideas that were going to take lots of effort I came up with this simple solution.
Using a dremel cut out just the area of the stud all the way through the grill. Used 1/4 by 1 1/4 elevator bolts cutting the hole just big enough for the base of the bolt to fit in the hole snug. The elevator bolt only sticks up about 1/8" when seated and clears under the molding . Follow along with the pictures to see how I did it. |
![]() Join Date: Oct 2014
Re: Repair turn signal housing studs in my grill
Great idea!!
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
Where did you find the elevator bolts ?
84 step side 87 swb |
