Motor Swap?
OK, I've got this motor....
![]() And this transmission.... ![]() Motor is an ~03 I think. 5.3 fairly low miles. Transmission is a mid nineties 4L80E. I think from a 4wd. I'm thinking about putting these two together in my '75 Blazer. It's gonna have to be cheap though. I've got several questions. Will the 5.3 PCM (which I don't have) control the earlier generation 4L80E? Is there a better (ie. Megasquirt, etc) controller for a budget to control both? The engine and trans will bolt together with a crank spacer, correct? What will I need as far as keeping the 4wd? I'm not completely opposed to keeping the fulltime, but if changing can be done cheap enough I want to look into it. I know a big chunk of these questions could be answered by searching, but this way I can keep it all in one place. Thanks in advance for the help.
Carson 1995 Sonoma--LT1/T56, full suspension mods, curvy road style <---Hasn't moved in years 1967 Camaro--undergoing restification <-- ![]() 1975 Blazer--thats what I'm here for 1978/84 C30 Crew Cab--Going to try for a spare parts build using mostly Suburban parts... |
Re: Motor Swap?
That's a 2wd trans in the pic. It has a 2wd tail-shaft housing w/a yoke.
A 4wd would need to have the adapter in place for a transfer case w/1 yoke going toward the front & the other to the rear.
Re: Motor Swap?
That's a 2WD transmission. The 5.3/4L80 combo won't be a bad one, but just so it's been said - if your skill level is such that you don't know the difference in transmissions, you should probably do a lot of keyword searching on this board and others before you even get into the details of your own build. Getting those two components to running/driving status in a '75 truck is far from a beginner task.
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
Re: Motor Swap?
I don't have any doubts in my skill level of doing the swap, only in my skill level of 4wd and automatics. This is the only one I've ever owned.
I've done a couple LT1/T56 swaps in the past. You can convert the tailhousing to the 4wds one, right? Is this 80E specific or will the 60E work?
#5 | |
Re: Motor Swap?
Re: Motor Swap?
Re: Motor Swap?
You need to either adapt your harness to control the 4L80E or you can buy a adapter harness.
But yes it will control it just fine. |
